K&N filter/fire arrestor |
rhschnauss
Newbie Joined: June-02-2008 Location: United States Status: Offline Points: 30 |
Posted: June-10-2008 at 9:19pm |
I was looking at a K&N filter/fire arrestor for a '85 2001 with the ford engine and a holley carb. Has anyone done one of these and which part # is best?
K&N part #'s 59-3264 9" around 3 3/4" high 59-3364 9" around 4 1/2" high 59-3370 9" around 6 3/4 high |
rhschnauss
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21169 |
I think the only one you stand a chance at fitting under your motorbox is the shortest one. The K&N's look nice, but dont expect them to add any performance- flame arrestors in general are not very restrictive. Id save your money.
Roy, Is the water you boat on real dusty? Just wondering why you are looking at a filter instead of just a plain flame arrestor.
rhschnauss
the belts produce some dust that gets on the engine and was covering the flame arrestor.
rhschnauss
boat dr
Replace the belts with high quality, adjust them to the proper tension and the belt dust will virtually leave. boat dr
Save your money to spend on fuel and not a K&N ....................................... |
rhschnauss
I actually switched to napa premium belts last season and noticed that they dont burn up quick like the pcm belts.
rhschnauss
nuttyskier2002
Gold Member Joined: September-28-2005 Location: United States Status: Offline Points: 669 |
NAPA belts are made by Goodyear and are hard to beat.
Former boats: 88 Ski Centurion Tru Trac II 59 Chris Craft Capri (woody) |
straylight
Groupie Joined: July-05-2006 Location: Germany Status: Offline Points: 60 |
I've noticed this continous wear and dust of my pcm belts as well and would like to replace them with better ones. Is there something like a "all-belts-for-a-standard-pcm-ford-351"-kit from napa? or which napa belts would i need? Tom |
I'd like to add to the Doc's comment on belt tension. Check the sheave alignment as well as the tension. Yes, there should be virtually no dust.
