fuel tank in 1968 Barracuda |
barr 68 ![]() Groupie ![]() Joined: October-21-2004 Location: United States Status: Offline Points: 59 |
![]() ![]() ![]() ![]() ![]() Posted: December-27-2004 at 7:17pm |
How is the fuel tank in a 1968 Barracuda supposed to be secured? Did the tank originally sit directly on top of the stringers? Thanks, Barr68
barr68
kenny g ![]() Senior Member ![]() Joined: December-13-2003 Location: United States Status: Offline Points: 318 |
no. two treated 5/4 boards across the primary stringers for the tank to set on.to hold it in place,two short pieces cut to fit the width.if u look at the tank it has a 1/4" welded seam on each end. use the wood to secure the tank,NOT METAL brackets.something about static electricity in an article i was reading.
kenny g
Rick ![]() Senior Member ![]() Joined: March-03-2004 Location: United States Status: Offline Points: 338 |
The tank I had was on the 5/4 boards as Kenny's. At both ends there was a small tab/seam. small pieces of 5/4 were cut and bolted so they pinched the tank seam to hole it in place.This was done by drilling a hole in the short pieces of 5/4 and then marking the long pieces to drill through. The holes in the long pieces were then moved 1/4" closed to the tank. When the bolts were tightened the short piece then sode up on the tank thereby pinching it. For insurance I also used 2 pieces of plastic banding strap like you see on wooden crates. If you need some Email me and I send it to you.
