how do I remove old letters from transom |
Author | ||
kman
Senior Member Joined: May-30-2008 Location: United States Status: Offline Points: 161 |
Posted: June-19-2008 at 12:43am |
What's the best way to clean off the old gunk/glue after removing the old boat name? Then does it need any prepping before I put our new name on? Thanks,
Kirk
1976 Southwind 20 Eagle Mountain Lake Fort Worth |
bill1
Senior Member Joined: May-27-2007 Location: United States Status: Offline Points: 151 |
i've used both goo gone and goof off.
bill
62 wood
Kirk,
Do you have the old letters off yet/ And I assume they are vinyl and not painted? (Bill is right on -if vinyl residue.) |
Acetone
skicat
Platinum Member Joined: May-18-2006 Location: Duluth, GA Status: Offline Points: 1129 |
I just removed some of the vinyl lettering from my BFN & I used the acetone like Pete said. Worked great!
Morfoot
3M makes an adhesive remover in a spray can that worked well on my pick-up but Acetone works just like the gang said.
kman
they are vinyl letters. I will try goo gone since that is what I have and my wife is killing me to get it renamed...
thanks |
Kirk
Kirt, Depending on how long the name has been on the boat, you may find a shadow from the old in the gel when you remove it. It is the virgin gel that hasn't absorbed dirt it the pores and hasn't beed affected by sun light. I have found that the surrounding gel can't be brought back to match. I have had to re gel coat a transom because of the problem. Just telling you incase your wife says something!!!
adamt
Gold Member Joined: July-18-2007 Location: Orlando, FL Status: Offline Points: 927 |
Just for curiousity's sake, what's the name that you are so eager to remove?!?! Was it worse than the offset "Wildman"?!?! |
-Adam
1973 Skier |
jbear
What could be worse than that?
No names on Correct Crafts anyway. Not needed. john |
"Loud pipes save lives"
adamt
Kingsberry's Lady comes to mind...perfectly offset as well... |
-Adam
1973 Skier |
62 wood
Adam, you may be glad to know... The "wild Man" is history!!!! I sure am glad its gone! ,...now , I just need to re-do the platform. Might be a good winter project? |
adamt
W H A T ! ! ! ! Wildman, what have you done?!?!?! |
-Adam
1973 Skier |
62 wood
Adam,
Ive still got the redneck platform in tact. I did clean and oil it tho... plus, you can still see the "ghost" image of the letters... |
SN2001fan
Newbie Joined: June-12-2008 Status: Offline Points: 26 |
https://www.autobodytoolmart.com/p-11255-13737.aspx
worked great for me. |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21169 |
You arent poking fun, are you Adam? My vote is to keep the name! |
kman
Current name is the name of the previous owner's wife: FRANCES B. We are renaming to "It's A Gimme!". Because the very nice PO gave me the boat!!! Thank you Mr. Taylor.
Kirk
RainDog
Platinum Member Joined: February-21-2007 Location: Mke/Grn Lake WI Status: Offline Points: 1387 |
You can wound, you can scar, but you can not kill the 'Wild Man'! |
