In need of a ski pylon: 89 Ski Nautique |
stimie02
Groupie Joined: July-22-2008 Location: Monroe, NC Status: Offline Points: 79 |
Posted: July-23-2008 at 1:40pm |
I am looking for either the top piece of the ski pylon or the entire ski pylon itself. I just recently purchased an 89' Ski Nautique 2001 where the previous owner had misplaced the top part of the pylon. Please contact me if you have one or can advise me where to get one. Thanks in advance ---- Stimie
Bro Stimie
Hollywood
Are you sure it's an '89? An '89 should have a 1 piece pylon with a rounded ball looking top, not one of those removable ring/fingers.
stimie02
Yeah it's definitely an 89'. There is another pole that slides over top of that with an attached grommet for securing a tow rope. The top of which is open kind of like the end of a pipe. I thought that a 3rd piece went into that open top and it had the removable ring on it.
Bro Stimie
You sound like youre describing an aftermarket extended pylon, not the factory pylon. You better post a picture to avoid further confusion. |
stimie02
Will do - thanks for the advice.
Bro Stimie
Hollywood
The "third" piece is probably the other half of your extended pylon with a cable, ratchet and strap to secure it around the nose of the boat.
stimie02
So do you think that the "2nd" and "3rd" pieces are from an aftermarket extension or do you think that they came as optional OE equipment when the boat was new?
Bro Stimie
backfoot100
I agree. This sounds like the bottom piece of a two piece extended pylon. They're aftermarket. Extended pylons weren't even a figment of someones imagination '89.
Eddie |
stimie02
I appreciate the insight from each of you.
Bro Stimie
