  New Posts New Posts RSS Feed - Starting
Starting
baumanmt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baumanmt Quote  Post ReplyReply Direct Link To This Post Topic: Starting
    Posted: August-11-2008 at 11:38am
I have a 1984 SN 2001 with a 351W, it has points ignition. I can get it started, but it takes some work. Is this normal, and if I switch to the electronic ignition would this help the issue? Thanks, Greg
gb842001
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2008 at 12:22pm
yes
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2008 at 12:44pm
Greg, Chris is correct IF the starting problem is ignition related. If it a ignition problem so will a tune up. What else have you checked and when was the last time a tune up was done?
74SkiNautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 74SkiNautique Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2008 at 6:50pm
You should clean and gap the points. I gapped mine at i believe...   .021" My 74 starts up on a dime!
74SkiNautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote baumanmt Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2008 at 11:17pm
Your guys are right. I posted back in 4-6-08 (points) about my point, cap and rotor, I need to call skidim and get the correct, new parts. The boat has run so good compared to my old one that it feels like it's running sweet. It has no problem pulling skiers or getting out of the hole, once started it runs great. I love correct crafts and can't wait to be getting the all out of the 628 hr, 1984 2001!
Thanks again, Greg
gb842001
