help with fuel pump |
96nauty
Newbie Joined: June-30-2004 Location: United States Status: Offline Points: 2 |
Posted: February-22-2005 at 4:03am |
I have a 96 ski nautique and the electric fuel pump does not seem to be working, it does not make that whining noise when I turn the key. I just dewinterized and it started one time and I heard the pump come on but it doesnt now. Now all it does is make a clicking noise when I turn the key any ideas? I dont know how the wiring works on these things but I did read that it is linked to the oil pressure gauge and my oil pressure gauge is acting funny. PLEASE HELP!
AlEx MuRrY
skyhawkflyer
Senior Member Joined: February-08-2005 Location: Zimbabwe Status: Offline Points: 275 |
Check for power at the pump (wiring harness). if you have power then the pump is shot. No power then you need to look elsewhere. That's just a start, hope it helps. TJ
Tim D
Grand Poobah Joined: August-23-2004 Location: United States Status: Offline Points: 2636 |
There should be a relay for the pump. Most fuel injection systems have the pump come on for a second or two when you switch to the on position before you hit the start position. This is controled by a relay and it's to help make sure there is enough pressure on the injectors. As for the oil pressure unit, on some systems, if there is no oil pressure, the fuel pump is shut down. But it's not instant oil pressure, because your car/boat wouldn't start so easy after changing the oil.
Tim D
skyhawkflyer
Iv'e seen guages that have become erratic after being stored in a humid environment (such as a moist boat that has been tarped). Sounds like you might have multiple problems. If you don't have power at the pump momentarily at start up then find the relay and check your connections. I've found more bad connections on my S/N than bad parts. Crimp connectors and the blue squeeze connectors with aluminum contacts are the worst, next to the aluminum automotive connectors. About 5 years ago I started soldering all of my connectors (crimp type) and have far less trouble. Hope this .02 worth helps.
TJ |
