  New Posts New Posts RSS Feed - Side Panel removal
Side Panel removal
rogier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rogier Quote  Post ReplyReply Direct Link To This Post Topic: Side Panel removal
    Posted: November-09-2008 at 12:16pm
Anyone know how to remove the side panels of a sport nautique 1992 ?
The space behind them is foamed in, so I cant see if there are bolts/christmas trees/ ?
Please advice howto remove.
Dave D. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave D. Quote  Post ReplyReply Direct Link To This Post Posted: November-12-2008 at 2:06pm
I too would like to know...anybody?? I would think that the coaming pads/side panels are held on by plasic clips. Does it tear up the clips to remove the panels and if so, can you find replacements?
Jetski180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jetski180 Quote  Post ReplyReply Direct Link To This Post Posted: November-12-2008 at 2:12pm
Are you looking to remove the side panels in the front of the boat or the back area of the boat? I know in my 94 Sport, to remove the back part there were about 4 to 6 bolts on each side panel. I think they were 3/4" or 9/16" bolts but not sure. If you are looking to remove the front of side panels I would think they would be plastic push in connectors but not sure, I haven't looked to close. Good luck.
Jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: November-12-2008 at 2:15pm
Ahh, combing pads. Wasnt sure what you were talking about- thought it might have been something specific to the Sport.
The combing pads can just be pulled right off- Dave is correct that theyre only held on by plastic clips. I would recommend new clips- some will break when removed. Try SECC or MWCC to see if they have any.
I removed mine so many times that the wood backing actually wouldnt hold the clips very well- I ended up putting 4-5 of these in per side... the panels dont fall off in chop anymore!
ripster92 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ripster92 Quote  Post ReplyReply Direct Link To This Post Posted: November-12-2008 at 2:26pm
On my 92 SN, I can't quite remember the size off hand (maybe 1/2 or 9/16), but there are about 6 studs that come through the coaming pads and are nutted from the back.
1992 SN Black w/ Yellow
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: November-12-2008 at 2:30pm
Wow, thats surprising- sounds like an improved design over what was in my '90. Better not just rip the combing pads off!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ripster92 Quote  Post ReplyReply Direct Link To This Post Posted: November-12-2008 at 2:35pm
Yes, and like Tim said, they tend to loosen up quite often, so put that on your regular maintenance list.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ripster92 Quote  Post ReplyReply Direct Link To This Post Posted: November-12-2008 at 2:43pm
Tim, It's possible that the PO may have added this "Enhanced" combing pad feature after dealing with the clips so long... I'm not really sure. They still come loose on a regular basis though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ripster92 Quote  Post ReplyReply Direct Link To This Post Posted: November-12-2008 at 2:44pm
Hey. That was my 100th post
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave D. Quote  Post ReplyReply Direct Link To This Post Posted: November-12-2008 at 2:46pm
Congrats, "Senior Member"!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ripster92 Quote  Post ReplyReply Direct Link To This Post Posted: November-12-2008 at 6:53pm
Just one more reason to crack a beer open!
Mojo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mojo Quote  Post ReplyReply Direct Link To This Post Posted: November-12-2008 at 8:10pm
Come on Steve, like you need a reason haha..
Moj'
05' SV211 TE
73' Martinique
had:96' SNOB
had:76' Nautique
had 77 Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote ripster92 Quote  Post ReplyReply Direct Link To This Post Posted: November-12-2008 at 9:37pm
Moj'
You blew my cover Moj
Post Options Post Options   Thanks (0) Thanks(0)   Quote rogier Quote  Post ReplyReply Direct Link To This Post Posted: November-16-2008 at 1:05pm
Thanks for the support, this means I have to dig into the foam behaind these panels to find those nuts/bolts.
Enjoy the beer
