  New Posts New Posts RSS Feed - New steering wheel?
New steering wheel?
kman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kman Quote  Post ReplyReply Direct Link To This Post Topic: New steering wheel?
    Posted: December-19-2008 at 6:38pm
Anyone know if there are any options out there for "smaller" diameter steering wheels? I know this will effect turning a bit, but the middle three gauges are nested right behind the top of the wheel blocked from view unless you are sitting on a cushion or lift up off your butt. I am changing out gauges to white faces for better visibility and would like to be able to glance at the gauges with less effort.
I'm 5'-11" so I don't think that is the problem. The top pic below is taken from a higher angle than where I sit. Any thoughts?
Kirk
1976 Southwind 20
Eagle Mountain Lake Fort Worth
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: December-20-2008 at 1:29am
Mine had a similar wheel,but was all broken up.The reason I remember it is because the hub which I still have is the same. I ended up using a Grant wheel and hub.My wheel is smaller than original but since I never used the larger wheel I don't know any better
03 limited 196 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 03 limited 196 Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2008 at 10:15pm
Gary...I just replaced my OEM Nautique wheel from my '03 196 Limited. If your interested let me know...I'm asking 50 bucks plus shipping...if you need pics contact me at cobra88@sbcglobal.net......Rogers A.
196 w/ZR6,Hot wife,Air Chair,Day at Lake Ozarks...priceless.
