  New Posts New Posts RSS Feed - What Jets should I use??
MaddMarxx View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MaddMarxx Quote  Post ReplyReply Direct Link To This Post Topic: What Jets should I use??
    Posted: February-13-2009 at 12:11am
Does anyone have an idea on what jets I should run in my 715 holley duel feed carb, it has 65s in the front and 68s in the back right now, but I think I could go bigger!
jbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: February-13-2009 at 2:22am
I think this carb is not good for your boat in my expert opinion.....might make it to fast.
john
"Loud pipes save lives"
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: February-13-2009 at 12:14pm
bump them up one - two sizes, I believe I had 72's in my single pump, but if you still have the stock cam then I wouldn't get to crazy, maybe one size larger on the secondaries.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: February-13-2009 at 1:30pm
MM, is that a 4160? I assume so. Sounds like you have a rear metering block conversion on that thing? You must if you have replaceable rear jets instead of the plate.
If thats the case, then (by memory) I think Im running 68 in front and 74 in the rear. I posted my numbers on here at one point- Ill see if I can find them. The rear needs to be ~6 steps bigger to make up for the lack of PV. I turn up to 5200 without any problems. Admittedly, I havent done a good plug chop yet, but performance seemed to improve as I went from overfat (72/82) down to this point. Holley's general recommendation was to go marginally fatter than stock (66/72), so this is pretty consistent with that.
backfoot100 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote backfoot100 Quote  Post ReplyReply Direct Link To This Post Posted: February-13-2009 at 5:54pm
Tim,
I talked with Mark last night about this. I completely forgot about the lack of a PV without the metering block. Good call!!!!!!
Eddie
LaurelLakeSkier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaurelLakeSkier Quote  Post ReplyReply Direct Link To This Post Posted: February-14-2009 at 9:44pm
I'm quite sure the power valve only affects the primary side no matter if you have the standard metering plate or the conversion block. It opens to give the richer mixture to the primary circuit about the time the secondaries begin to open up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: February-16-2009 at 12:32pm
Thats correct. No PV in the secondaries means that the jets need to be larger to balance them out.
reidp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote reidp Quote  Post ReplyReply Direct Link To This Post Posted: February-28-2009 at 11:36am
Originally posted by MaddMarxx MaddMarxx wrote:
Does anyone have an idea on what jets I should run........
Mark, while all of the previous jet suggestions sound good, if your main objective is to run with the Boatdr, I suggest your only option is to go with one made by Pratt and Whitney.
Just in case.......
http://www.pw.utc.com/vgn-ext-templating/v/index.jsp?vgnextoid=c3ca34890cb06110VgnVCM1000004601000aRCRD
ReidP
1973 Mustang
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: February-28-2009 at 1:24pm
I gotta laugh, im taking what appears to be a 650? marine and a 600 auto and combining the 2,i hope to end up with a good carb, im using the float bowls from the auto, drilling the base on the marine for vacuum, too cheap to buy another carb so I'll give this a shot on a buick 350. both carbs are in new condition. there definitely was a difference in the CFM of the carbs because the marine was around .050 larger. i need to run the numbers. will post in the future if it will even start lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: February-28-2009 at 2:39pm
Still think this is a bad idea...way to fast.
MM...did you see the thread about the distributor? I think I might need this...what do ya think?
john
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: March-06-2009 at 2:56am
Make sure the Carb is Marine. Automotive carbs are built so that if there is to much gas it spills it out of the carb down the intake to the ground. For obvious you don't want this to happen in a boat because it fills the bilge with gas... Not a good thing. You need to make sure the throttle shaft isn't grooved and the overflow is curved back into the front barrels. Holley sells this tube if you need it.
SS 201 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SS 201 Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2009 at 9:39am
GOOD POINT
THE DIFFERENCE BETWEEN AUTO AND MARINE IS J TUBES TO PUT THE FUEL BACK IN THE CARB RATHER THAN BILGE. ALSO MOST MARINE ARE ALREADY SET A LITLE RICHER THAN AUTO.
BEFORE JETTING UP OR DOWN BE SURE TO READ THE PLUGS FIRST. PLUG GAP AND ELECTRONICS CONTROL THE PLUG READING, SO TOO MUCH FUEL WITH A LOW VOLTAGE OUTPUT WON'T BURN PROPERLY.
ALSO THE FUELS TODAY DON'T ALWAYS SHOW GOOD READ, ADD A LITTLE OCTANE BOOSTER AND IT WILL CLEAN UP THE BURN.WILL SHOW REDDISH COLOR WHEN JETTING, HELPS WHEN CHECKING PLUGS.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MaddMarxx Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2009 at 1:50am
Yes it is a marine carb it was off of my buddys Donzi, and it had really big jets in it, so when we rebuilt it we down sized the jets, I just have not had the time to work out all the bugs out, I do have to do good plug check, but it seemed to be running lean!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SS 201 Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2009 at 9:14am
MOST 600 CFM NON REAR PLATE USE STOCK 65 F 76 R.
GO TO MORTEC.COM IT CAN ANSWER MOST ALL OF YOUR CARB QUESTIONS.
AGAIN REMEMBER YOU ENGINE CONDITION AND IGNITION CONTROL HULL ,PROP ARE FACTORS IN THE JETTING OUTCOME. BIGGER NECESSARLY IS NOT BETTER.WHAT ONE RUNS DOES NOT NECESSARLY FIT YOUR NEEDS. LOTS OF VARIBLES GO SLOW IT IS CHEAPER THAN MAKING RASH OR COPY CAT DECISIONS.BEEN THERE DONE THAT.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MaddMarxx Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2009 at 11:17pm
Its a 715 cfm!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SS 201 Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2009 at 5:06pm
715   72 f 84 r
boat dr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boat dr Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2009 at 10:24pm
Mark , I may be out of line here , but why not put the 4160 back on it. You do not have enough mods on the motor that would require the extra CFM nor the hassles that go with the jetting.
One more thought , those bowls with the external float adj. are not marine complient.Did you not loose MPH by adding this carb?
Unless there were major issues with the stock put her back on.
My stroker is moving a lot more air and turning 5900 rpms with a stock, YES STOCK, 4160 and as you know who took the trophy home..........Boat dr
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2009 at 12:02am
we did some calculations with boat weight to engine ratios doc, your boat should actually be doing around 70, you sure your plugs are OK?
Post Options Post Options   Thanks (0) Thanks(0)   Quote boat dr Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2009 at 3:16am
Eric, I have done more running than calculating. But read them and weep...
12x15 @5000 rpms =66.25 actual 53.02mph
12x15 @5100 rpms =67.61 actual 54.08
12x15 @5400      =71.59 actual 57.27
12x15 @5600      =74.98 actual 58.96
As you can see there is a big difference between theoretical MPH based on pitch and RPM and actual GPS speed.
The slippage rate climbs very steeply after 4500 rpm's. 20% or so down low then climbing as you spin it higher........
