  New Posts New Posts RSS Feed - proper prop installation
 Post Reply Post Reply Page    <1 234
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-16-2016 at 12:31pm
Russ,
Water base will work just fine plus it's easier to clean up! The Prussian blue is optional as it's just a good indicator of high and low spots.
Russman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russman Quote  Post ReplyReply Direct Link To This Post Posted: May-16-2016 at 12:39pm
Thanks,     I was going to install yesterday, but when I went outside to head to the unheated barn I moved the boat to from heated storage it was way too cold and I decided that an inside the house job was in my interest.    Warming up this week so I will get it then.
1989 2001 SN / Prior 1978 Cobalt 18
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russman Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2016 at 10:45am
New 422 installed. I am glad that I decided to change the prop this year as when I went to change the screw was loose and the prop just fell off the taper. I am thinking that I am fortunate that I did not have any trouble last season.
I lapped the shaft as mentioned in this thread and ended with a nice fit.
Here is a pic, Cleanup of underside of boat is needed!!!!!
I also need to do some serious trailer work in the fall.
TedR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedR Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2016 at 11:02am
What a great and useful post Peter, thanks for all the info...
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2016 at 2:29pm
This is a fantastic and helpful thread for sure Pete, Very kind of you to share the knowledge with us clowns. I got away with not lapping for over 25 years but I now know that was wrong.
One point on torqueing the prop nut.   30-35 pounds of torque is not very much.
Even small cars torque the wheel studs to 90 pounds torque so keep in mind how little 35 pounds is. Most of us have changed a tire on our cars and know how tight that is.
The prop nut is about 1/3 that tight.   An impact gun could blast that nut down to 150-250 pounds in a quick application of air power.   Using a 2x4 to tighten the nut?   Any water skier has plenty of grip in your hands to hold the prop with one hand while tightening the nut to 35 foot pounds.   If you need a 2x4 you are way too tight.
Using a crescent wrench on the nut, if adjusted properly I see zero issue using the adjustable wrench for this little amount of torque.
I should follow up with my observation, in the old days before lapping changing a prop was really easy.   I never had to fight getting one off because they were installed badly and I did not know it. A lapped prop will need a tool to remove it every time, showing you did the job correctly and safely.
I also had the clank of the prop hitting the nut when put in reverse before I started lapping, that clank going into reverse should be a red flag for any inboard boater.
Pete"s advice should be listed as gospel on this issue.   Thanks again and I hope all the new guys get a chance to read Pete's advice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2016 at 3:36pm
Mark,
Thanks for the compliment but I wasn't the one who started the practice. Notices came with the Acme CNC props recommending lapping. I simply did the pictorial thread. I mentioned it in the tread that I have a feeling the recommendation is due to the taper bore being machined and not reamed. The machining will leave a rougher finish than reaming but lapping will remove the roughness. The actual lapping practice has been with us for many years in the tool and die trade. In fact, Duane's old enough to have actually been involved with the lapping inception!!
Duane in Indy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2016 at 4:22pm
Pete, We used to lap horse shoes before the car came along.
(BTW we are only about 2 years apart)
        1978 Mustang (modified)
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2016 at 4:33pm
Duane,
I knew I'd get you up from that afternoon nap!
I've heard that lapping went back before the pyramids were built. Sand was placed between stones to be fitted together, then one was moved back and forth and the high spots would get ground off.
TedR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedR Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2016 at 6:23pm
Delta even threw in some gratis beer coozies!
geecee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote geecee Quote  Post ReplyReply Direct Link To This Post Posted: November-30-2016 at 8:08am
Just pulled my prop to have it rebuilt and after reading this thread realized it had a stainless nylock on, I did not have any issues taking it off, but when I reinstall I would like to get the right thing.
What should I get if not stainless?
1983 Ski Nautique '2001'
-Chev 350 Mercruiser
-Custom Wake Tower
-Custom Interior
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-30-2016 at 8:10am
Brass
Post Options Post Options   Thanks (0) Thanks(0)   Quote geecee Quote  Post ReplyReply Direct Link To This Post Posted: December-01-2016 at 8:49am
Thanks,
-Custom Wake Tower
-Custom Interior
