fuel filter |
slalomjunky
Groupie Joined: August-25-2008 Location: United States Status: Offline Points: 42 |
Posted: May-11-2009 at 11:17pm |
I have a 1194 ski with throttle body injection. It has the remote fuel/water separator filter with the reusable bowl. I have never replaced it and am thinking I should after this many years(although only have 410 hrs on her). It has a PCM part number but is also stamped with the actual manufacturer's name "Racor". Any body have any idea what a replacement part number from Sierra or racor or any other brand that would fit would be? Where is the best place to buy? Also any ideas where I can get the white gelcoat already matched to my hulls color? Can anyone tell me definitively if my boat has would in the floor? I was under the impression when I bought it new in '94 that was the year they did away with any wood in the boat except for the combing pads. I have a soft spot on the port side next to the motor compartment between the stringers. Trying to decide what to do. thanks for you help
Utah '94 Ski, '03 Malibu SS LXI
azeus17
Gold Member Joined: August-19-2007 Location: Grand Rapids, M Status: Offline Points: 576 |
Go to Skidim.com for the fuel filter. There are a couple different sizes, long and short, I believe. Use CCFAN and get a discount as well. Starting in '93 CC's are all composite. Your '94 should be safe.
Boats:
Current: 02 SANTE Sold: 89 Sport Nautique |
SNobsessed
SlalomJ - Someone else with a all-composite SN had a soft floor recently. It turned out to be the foam degrading under the fiberglass floor. It's really not hurting anything (no wood to rot) but if it bothers you, pull up the carpeting & cut up the floor. You can repair the foam, then re-fiberglass & put down new carpet. Or forget about it & go skiing!
slalomjunky
Thanks guys for the info. I thought I was right about the floor but just wanted to check. Thanks for the lead on the fuel filter. You all have a lot of knowledge. Much better than trying to track down some one from Nautique or PCM. I have found that not even th "experts" really know what they are talking about. You guys live it and know it. thanks Kerry
