Shaft strut bushing replacement time |
horkn
Posted: June-20-2009 at 2:48am |
So, My 78 martinique is needing a new bushing for the shaft strut.
If I am reading this correctly, I need these http://www.skidim.com/prodinfo.asp?number=SB10X12 What are your thoughts on the plastic ones? I read here that taking the DS off, then the set screws out, then using a sawzall at the top from the rubber inside towards the brass, and then trying to take the bushing off does the trick. if not, then cut the bushing through 180 degrees at the bottom and try it again. Is putting the new one in as simple as plopping it in, then tightening the set screws, and then re insert the DS? I of course will check alignment at that time too. if I can get this taken care of, and my timing set correctly, i might be able to hit the GL event up this year finally. Tom |
86BFN
Gold Member Joined: July-28-2008 Location: Indiana Status: Offline Points: 882 |
Yes, those are it. I wanted to try the XPC bushings but some on here didn't prefer them so I went with the brass & rubber. I used a hacksaw, as I was not in a speed contest to get them out. I had to cut mine twice. To re-install, get a threaded rod with nuts and washers and pull the new bushings into the strut, don't try to pound in with a hammer. I also put a thrust bearing below the nut and it worked sweet. Good Luck.
eric lavine
Horken, dont over tighten the set screws and dis-figure the bushing, Ill go in with a drill smaller than the hole and drill the bushing a touch, lightly hand tighten with loc-tite
SNobsessed
Tom - Freezing the bushing right before you install will help them go in easier. You might want to clean up any corrosion in the strut bore before install, that will help too.
horkn
Good info guys!
I will keep you posted. The frozen bushing option will definitely help. Most times I am working on whatever you can't try that because the parts are too big. Not this time. Eric, If i am understanding, you take a smaller drill bit than the threaded hole for teh set screw, and while carefully not mucking the threads on the strut, you get a dimple started with the small bit so the set screw has a place to call home? If so that makes perfect sense. Blue loc tite is my friend:) I was planning on using that to hold the set screws. Now these 2 bushings need to have their flutes lined up with each other , right? What other online place has these? I am trying to get these for as cheap as possible. I have a limited budget unfortunately. |
79TiqueRebuild
Senior Member Joined: January-21-2009 Location: Kansas City, Mo Status: Offline Points: 238 |
You might look here.
go2marine |
horkn
Those look to be the same price,if not more for the size I need, and then there is the chance of ordering the wrong ones.
eric lavine
exactly, and I even coat the hole with loctite when i slide it in actually press it in
horkn
ahh, lube-tite then LOL
eric lavine
lifes to short not to laugh
eric lavine
I notice your one of the few that runs a 4 blade, any feedback?
jbear
New meaning to the term "tight embrace" brunstucky style... Sorry eric..tried to resist but couldn't. john |
"Loud pipes save lives"
eric lavine
John, you do know the toothbrush was invented here in Brunstucky.....anywhere else they wouldve called it the teethbrush
Riley
The threaded rod does the trick, but that fit is so tight, I can't imagine locktite is needed, or even the set screws, although I did do the dimples and install them.
I like Go2marine because they have a 4" bushing which I like better than 2 2" bushings and their prices are the best. |
horkn
I LOVE it. I have run this prop since the first summer I got the boat. Skidim said not to run a 4 blade, but talking with acme, they guaranteed it would be good. I did ding it a tiny bit last summer, so until I get it repaired, I will be running the stock 3 blade once I get her going this summer. From what I recall, the 4 blade gave me more top end, and definitely more grunt out of the hole. Pulling 5 skiers on 2 skis each was actually less work on my 78 than with the year old air nautique with like 70 more hp at the time. Granted the newer air had a lot more weight to haul, but I added a good 500 lbs to my boat when I redid the flooring. |
horkn
I was wondering, that it appeared to be a single piece on go2marine. I like that idea better as well. |
jbear
I did know that interesting fact. You have your cell phone turned off this afternoon? john |
DrCC
Check out (if its not too late) deepblueyachtsupply.com
1"X 1 1/4" X 4" for less than a 35 dollarbill AT |
horkn
It's not too late, I have to get the motor running right first, so I will check that link out. the price sounds great! So that is the correct size I need? 1x 1.25 x 4" ? Thanks for the link! Tom |
saffer
Senior Member Joined: March-29-2008 Location: New Zealand Status: Offline Points: 113 |
Hi guys
Just ordering a package from Skidim. Which is the correct part number for a 1" shaft for the strut bushing? Also (tried to figure it out from post above) must i remove strut from boat,or is it easier to get coupling apart? (prop is still off)to deal with this issue? |
SNobsessed
Saffer - Call Vince at SkiDim or Karen at Correct parts - they will make sure you get the right bushings.
I would rather take the coupling off & remove shaft vs. removing the strut, unless the strut is already bent (then it must come off). Before you take either apart, unfasten the coupling & see where the shaft is 'happy' in relation to the shaft log (remove packing hose to view or view from underneath. If the shaft wants to be off center in the log, your strut is bent. |
saffer
ta SN
no bends in shaft as i can tell from all my looking. I will mail skidim n ask them. already done alignment before winter, no noarding done for a few months now. Will recheck everything. |
saffer
ps.
to remove coupling you use the 4 bolt method eh. |
MikeRa
Newbie Joined: June-28-2009 Location: Charlotte, NC Status: Offline Points: 12 |
I've got an '80 Ski Tique that I'm rebuilding. The old shaft strut bearings pretty much slid out easily once the set screws were removed. New strut bearings (2x2") also slide in easily. Is this normal/desired?
I saw your post on lock-titing the strut bore prior to bearing installation as well as drilling dimple in bearing for set screw. Is is normal to see loose fit between new bearing and strut??? Any help much appreciated? |
Mike,
The answer to your same question in the other thread:
I'd stick with the standard 4" long brass/rubber cutlass. |
SNobsessed
Mike - I don't think loose bushings are normal but Pete's advice to locktite them in is very good. You don't want those working loose during operation!
