Trans dipstick question (Velvet Drive 71C) (pic) |
randall
Senior Member Joined: July-30-2004 Location: United States Status: Offline Points: 123 |
Posted: July-10-2009 at 4:57pm |
Does this look right? I have always wondered but haven't gotten around to asking.
Does it look original or broken and repaired?? Thanks all. |
1973 CC Mustang
It sure looks like somone changed the level or used a different dip stick from another model! There's a real nice chart in the B/W velvet Drive manual that gives you the dimensions from the underside of the cap. So you don't need to go look it up in the reference section, here they are.
The overall length or the low point of the oil level on the original is 4.64". The length to the high level is 3.81" from the underside of the cap. If yours is different, post it and I'm sure Eric will comment. |
Riley
I have seen new lines marked on before so you could check the level when the boat was cold or to compensate for angle, but have never seen it done like that.
randall
THANKS! I will check the measurement.
The part that makes me think it was intentional and not a "break and just slap it together" is that the break lines (metal ends) don't line up exactly. They really don't look like they ever fit together (at least not in these exact two piece ends). |
1973 CC Mustang
Oh, it's intentional. No one goes to the extent of spot welding two broken pieces together like that!!
BTW, whoever did the spot welding, had the heat and tip pressure cranked way up!!! But, it did the job!!! |
randall
According to your measurements, it is approaching 1'' off. In the past, I had suspected that and ran it just near or slightly above the low mark. (to compensate for the difference in the overlap - just in case).
So now, the end of the dipstick is "low", and the low mark is "high"... I got some good time in running her this weekend. I caught some late afternoon glass myself with our 1950s wooden slalom. (picture) Nothing like cruising on this antique ski behind the mustang in the late afternoon. |
1973 CC Mustang
eric lavine
someone may have modified a V-drive stick which was longer, alot of the 71c's had screw in dipsticks. it does look like the full mark is a little high. as suggested check and re-mark
randall
Thanks all.
I read through the manual a little and noticed the explanation of a COLD vs WARM dipstick reading. Just maybe, the higher marks could be for an accurate COLD (drain down from cooler and lines) reading. (you think??) I will keep checking closely and will test exactly with COLD vs WARM. Also, while on the subject, I was going to change the fluid this Sept. WHAT IS THE EASIEST WAY TO "CATCH" THE OLD FLUID? I haven't done it before. From what I read, you drain from the lower hose connection. Doesn't look like much room to manuever that close to the bilge floor. THANKS. |
1973 CC Mustang
Hollywood
No don't do that, way more trouble than it's worth. Suck it out the dipstick hole with a hand pump. In this picture the shorter tube will go into the transmission. I suggest leaving it longer (this one looks cut) or glueing/hose clamping it on to the pump body. Do not let it fall into the transmission! |
