  New Posts New Posts RSS Feed - Shafting tollerance
Shafting tollerance
Rick View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Topic: Shafting tollerance
    Posted: April-12-2005 at 4:04am
Just pulled the prop and shaft out my 64 skier, the prop shop guy said I need a new shaft, it was out of round by .013, said acceptable was .003..??? I don't want to drop 400 on a new one. I have not put the boat in the water yet and want to see if there is a vibration problem, and if so how much. I was also replacing the strut bearing, as the original one is pretty shot...Any advice would be great
Jim_In_Houston View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: April-12-2005 at 4:22am
Rick, if by "out of round" he means it is bent, .013" is excessive. Personally, I like to see the shaft to be straight within .001". From what I have seen .003" seems to be the boat industry standard as a "go no-go" measurment. I would not run a shaft that was bent by .013". You could damage other parts of your drive train. A lot of machine shops can straighten a shaft saving you the cost of a new one. You should take your shaft and shop around at local machine shops. The shop does not have to specialize in marine work to straighten a shaft. Tell the shop you need it within .003" garanteed and ask for an estimate. Tell them if they can't get it within .003" you don't need it. Don't let them try to straighten it, get it within some lesser tolerance, and then charge you anyway. It does not hurt to ask if you can see them check it for straightness. Good shops will let you watch. (I owned and ran a shop in Houston for 20 years.)
By the way, I've seen new shafts on Ebay for a lot less than $400.00. I bought a new shaft for my '68 for about $250.00.
skyhawkflyer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skyhawkflyer Quote  Post ReplyReply Direct Link To This Post Posted: April-12-2005 at 12:57pm
chances are it was the shaft (vibrating) that took out your strut bearing, (even tho it is old).
Something to think about: if your shaft is bent .013, then the wobble on one revolution will be .026
If your running an old Federal or Michigan prop you may or may not feel any vibration because the prop is not nearly as precise as the new ones, where as you would feel a vibe with a new prop.
My .02 worth: if it doesn't vibrate, run it. If it vibrates get a new shaft (splurge for a prop too). Depending on what prop you have it may inhibit or amplify the problem.
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: April-12-2005 at 1:19pm
Rick:
I paid $145.00 + $25.00 (second taper) for a double taper 1" shaft of custom length. I also had to pay $110.00 for a new billit aluminum coupler for the tapered shaft. So, I would bet that a single taper shaft can be had for about $145.00 (51" long) if you shop around. My shaft came from McDurmon Marine Distributing via my prop guy.
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: April-12-2005 at 6:25pm
A friend of mine got one made for his '86 nautique for $150 at a place here in NC that repairs props and makes shafts.
Tim D
