  New Posts New Posts RSS Feed - Knocking when idling in gear
merrittarnold View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote merrittarnold Quote  Post ReplyReply Direct Link To This Post Topic: Knocking when idling in gear
    Posted: July-28-2009 at 9:00pm
I was riding in the back while my wife was driving. I noticed that when she had the boat in gear but was just idling there was a mild tap-tap-tap sound. It was either coming from the floor behind the engine compartment or inside the back of the engine compartment; probably both. However, when she gave the engine some gas to pull a skier, the knocking either stopped or was drowned out by the engine. We had too many people and too much equipment in the boat for me to do a thorough search on the water.
Is this noise normal? dangerous? simple to fix?
There are motorcycles; and there are Harley Davidsons.
There are tractors; and there are John Deeres.
There are ski boats; and there are Ski Nautiques!
Luchog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luchog Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2009 at 9:10pm
from your description it could be many things, you need to do a little more investigation.
anthonylizardi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote anthonylizardi Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2009 at 9:50pm
Read about damper plates. Is a common thing specially if your boat alignment is off. Tons of stuff on that and alignment
86BFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 86BFN Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2009 at 10:13pm
Most important of all, blame it on wife! LOL Sorry I'm no help.
👣 Steve
86 Barefoot Nautique
89 Martinique
Former Owner: 93 Hydrodyne 350 MAG
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luchog Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2009 at 10:48pm
what's your rpms at iddle speed? sometimes if they're too low bumping them up will solve the clanking sound.
Post Options Post Options   Thanks (0) Thanks(0)   Quote merrittarnold Quote  Post ReplyReply Direct Link To This Post Posted: July-30-2009 at 1:27am
I know it idles at 800 when not in gear. I'm not sure what rpm when in gear. We will probably go Saturday if the weather allows. I will do more investigation, but what exactly should I look for?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luchog Quote  Post ReplyReply Direct Link To This Post Posted: July-30-2009 at 4:37am
you want to see how much they lower when you put the boat in gear, feel if it makes the noise and then give it a little gas until it stops clanking.
