  New Posts New Posts RSS Feed - Raw water impeller 1974 mustang
307 STANG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 307 STANG Quote  Post ReplyReply Direct Link To This Post Topic: Raw water impeller 1974 mustang
    Posted: April-17-2005 at 6:25pm
My 74 Mustang is leaking from a seal behind the raw water pump. Does anybody know where I can find parts for my pump? I have a OMC 225 HP (307 cu in) motor. I don't see chevy powered mustangs.
The pump does not have any manufaterer name on it. THe impeller has 6 blades ,is 4 1/8 inch in diameter and the pump shaft whole is 7/8".
1974 mustang 225 HP OMC
swamp demon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote swamp demon Quote  Post ReplyReply Direct Link To This Post Posted: April-17-2005 at 9:49pm
try any old omc dlr just call around.
There wern't a lot of omc's put in cc but the ones i'v seen ran like a banshee
Rosser View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rosser Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2005 at 1:00pm
Try White Lake Marine,910-862-3688.They are the oldest CC dealer in the world.www.whitelake.com
1971 Skier holman&moody 1971 Mustang holman&moody
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2005 at 4:15pm
A friend of mine has a Mustang 17 with a chevy motor, the only one I've ever seen. Your pump might be a Johnson or Jabsco pump, the sherwoods have more impellors. Look at the differnt pumps on Skidim.com.
Tim D
JEFF KOSTIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JEFF KOSTIS Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2005 at 1:35am
MY GRANDFATHER BOUGHT A NEW 1974 M17 WITH THE OMC 225. IT WAS USED FOR 10 YEARS, THEN STORED INSIDE FOR 10 YEARS UNTILL I MADE IT WATER-WORTHY AGAIN. I HAD THE SAME PROBLEM WITH THE PUMP AND PULLED IT APART, CLEANED OFF THE SLIGHT BURR ON THE SHAFT, THEN WENT TO MY LOCAL BOAT SHOP (NOT A OMC DEALER) AND PULLED NEW SEALS RIGHT OFF THE SHELF AFTER MATCHING THEM UP. APPARRENTLY THE SEALS FIT OTHER UNITS. THIS WAS ALSO ABOUT 9 YEARS AGO. RULE OF THUMB I LEARNED... NO MORE WATER, NO MORE SEAL!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 307 STANG Quote  Post ReplyReply Direct Link To This Post Posted: April-21-2005 at 9:12pm
Thanks for all of the info to everyone. I will let you now how it turns out. I am impressed with this website.
nautique frk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nautique frk Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2005 at 9:06pm
Contact Karen or Vince at Discount Inboard marine in Columbia S.C. , They have a link on this site , They should be able to help you out ,
It has got to be ethier a jabsco or sherwood pump .
Mike
