Speedometer Pitot Tubes |
skyhawkflyer
Senior Member Joined: February-08-2005 Location: Zimbabwe Status: Offline Points: 275 |
Posted: April-20-2005 at 2:08pm |
When you run your boat and your speedometer pitot tube clogs with debris what do you use to clear it? Post your idea's.
I use a small drill bit that I keep in my glovebox. Turned clockwise, it tends to pull the debris out. |
David F
I use "canned air" (the stuff you buy to blow out your computer keyboard. I disconnect the air hose at the back of the speedo and use the canned air to blow the debris out the way it came in. Works 90% of the time.
74 Skier
Newbie Joined: March-11-2005 Location: United States Status: Offline Points: 35 |
Do a "whirlybird" that'll get r dun!!
1time17
Groupie Joined: July-27-2004 Location: United States Status: Offline Points: 76 |
i take it apart at speedo and at pick up and hit with some copressed air for a sec that all it takes..
gotta love those old school nautiques
custom2001 |
66polyhead
Senior Member Joined: December-20-2003 Location: United States Status: Offline Points: 171 |
H@#$ YEAH! A 180 @ 40 m.p.h.!
66polyhead
I use a #2 needle till water shoots back out. Mine always seems to stick at 32 m.p.h....?
Morfoot
I use a syringe with a short section of rubber tubing (the same size and diameter already attached to boat)and use water pressure to dislodge the obstruction. Be sure to install the hose on the syringe with RTV so as not to lose it.
nautique frk
Platinum Member Joined: February-16-2004 Location: United States Status: Offline Points: 1784 |
Air from the speedo end and a large paper clip at the pick up end , when needed , Not to often
mike |
