Throttle body fuel-injection |
d killough ![]() Newbie ![]() Joined: April-05-2005 Location: United States Status: Offline Points: 5 |
![]() ![]() ![]() ![]() ![]() Posted: April-21-2005 at 3:48am |
I have a '95 Pro Boss 351 EFI. One of the injectors seem to be clogged (or something else is going on) Where would be a good place to send the whole EFI throttle body (carb) to have it fixed. I do not have a Nautique dealership in my area. It only boggs at full throttle.
SKI DADDY
David F ![]() Platinum Member ![]() Joined: June-11-2004 Location: United States Status: Offline Points: 1770 |
First thing I would do is check to make sure you are not in limp mode. Two sensors trigger limp mode...high temperature and low oil pressure. Both have their own sensors dedicated to this function.
Next thing I would do is add a fuel conditioner/cleaner. The best I have every used is made by BG products called 44K or something like that....drawing a bit of a blank. The product is hard to find and not sold in retail stores. It is a professional product that should be available at car dealerships and independent mechanic shops. It really works, give it a try. |
swamp demon ![]() Groupie ![]() Joined: March-15-2005 Location: United States Status: Offline Points: 55 |
Try changing the fuel filter. If you havent changed it in a while
watermutt ![]() Newbie ![]() Joined: August-19-2004 Location: United States Status: Offline Points: 10 |
check anti-siphon valve on tank if yours is equiped with one
