Volt Meter |
Texas88
Newbie Joined: April-23-2005 Location: United States Status: Offline Points: 19 |
Posted: April-23-2005 at 2:41am |
I have an 88 SN, 351 PCM, new ski dim 50 amp Alt with internal reg. I just had a couple questions that someone may know. How do you test to see if the in-dash volt gauge is accurate, or even working. And how do you measure how many volts the Alt is putting out. I have a hand held volt meter.
Thanks, |
nates78ski
Platinum Member Joined: January-24-2005 Location: United States Status: Offline Points: 1041 |
First the gauge test is take your handheld meter check the voltage across the battery. The dash gauge & voltmeter should read the same. Marine voltmeters are not exactly the most accurate devices by are fairly close if working properly. The alternator output voltage running should be between 13.6 vdc. & 15.5 vdc.. Any less and the battery will loose charge. Start the engine with the handheld across the battery you should read between these voltages @idle. You may see some increase up to 2000 rpm. The dash gauge should read close to the same. If the reading on the dash is off check all connections to the gauge including the ground. You might even pull the dash unit and hook it across the battery to see if the readings are close. This eliminates the wiring in the boat when checking the gauge.
Texas88
Thanks Nate,
I ran the tests and found about 13.5 at the Alt and the Gauge, all appears to be fine in Nautique Land. Thanks, Bryan |
skyhawkflyer
Senior Member Joined: February-08-2005 Location: Zimbabwe Status: Offline Points: 275 |
What does your in-dash voltmeter read? My 87 reads about 10 volts, but I've probed around and found right where the voltage drop is at on one of the buss bars. I haven't replaced the wire yet but was wondering if anybody else had these symptoms. It also has a weak horn, due to the same wire.
jameski
Senior Member Joined: May-18-2004 Location: United States Status: Offline Points: 368 |
On my '78 the in-dash volt meter reads 12 when my engine is running, 10 when it's not running. I've checked with a DMM and the new alternator is putting out exactly what it should; it is actually around 14 running, 12.5 not running.
JEFF KOSTIS
I know for sure the older Mustangs (74 and up), were famous for inadequate wire size from the engine to the dash. They only had current meters in the dash(at least all that Ive seen). This causes any add-on or factory installed volt meters not to be accurate if wired at the dash panel and not at the battery. You may have an alternator that puts out 14.2vdc at the output stud, yet only get 12.8 or so at the dash. This is due to excessive voltage drop in the wiring. The more that is drawn, the more the drop is. Voltage drop in a wire of a certain length and current draw can be calculated. My boat had a factory #10awg hot and ground wire to feed the dash and accessories. I got over 2 volts of drop with the lights and blower on and less than .5 volt drop when shut off. Unlike house wiring where you can draw 30 amps off a of #10 wire, if you get a 5 volt drop- who cares, everything is to spec, but loose 5 volts from 14.2vdc and youre in trouble! If anyone has any wiring/current/voltage/ohm/electrical Questions feel free to ask because I may have questions with fiberglass/gelcoat/ where Im lacking alot of knowledge.
skyhawkflyer
Jeff, You are right on the money!
I probed around my 87 Ski Nautique and I found the voltage drop comming from the hot wire at the key switch that feeds the + side of the accessory buss bar. The wire is inadequate and smaller than the negative feed to the other buss bar. I traced my voltage drop right to the wire. I haven't fixed it yet because it looks like I might have to pull the instrument pod to gain accesss. Probing around other area's I found very small drops, hope this helps. |
JEFF KOSTIS
Skyhawkflyer, usually theres a larger #10 or #8 hot wire coming from the engine where it goes to a busbar in the dash, then split into several fused lines, one being the ignition key. Does the output of the key go to another bussbar? Because if it is connected like that you might get away with adding a simple relay from the main bus bar to key switch bus bar. I need a bit more info on how its wired cause im not real familiar with newer boat wiring methods. Might also want you to try a few more measurements to be sure. let me know..
