stringers |
alsy
Newbie Joined: April-20-2005 Location: United States Status: Offline Points: 4 |
Posted: April-25-2005 at 1:08am |
hi guys,
I have a 73 marauder. I'm replacing the stringers and wonder if anyone out there knows what wood was originally used. Also, anybody that has replaced them , what wood did you use? Thanks Al Syssa |
fly hi
DJ 77 skier
Guest |
nnot sure what it had but use untreated wood for new stringers the resin will not bond to the treated wood
David F
DJ:
Epoxy resin (no experience with polyester) will bond to treated wood IF the wood is properly "cured" before using. What I mean by properly cured is that the wood is left in the sun for several weeks to allow the wood to dry and evaporate off some of the chemicals that are at the surface. Once this has been done, the resin will penetrate and bond to treated wood. However, it is tough to keep the treated wood straight during this process, so it might be wize to purchase several stringer candidates in the hope that one will stray sufficiently straight. FWIW, I THINK that kiln dried Douglas Fir was originally used for the stringers. Not sure on this one, but I think if one were to read some of the brochures prior to '93, it may reference what type of wood is used. |
alsy
DJ & DF
Thanks for your suggestions. I think Doug fir (kiln dried) is the best route to go. I will see if I can find some scaffold grade Doug fir. Definitely will stay away from "green or treated wood". Haven't seen any ref. to type of stringer wood in cc brochures. Thanks agn. Al Syssa |
fly hi
David F
I found it...look in the 1990 brochure. It mentions kiln-dried Fir stringer sytem in the "new decade (2)" page. I guess I assumed the Douglas part.
Jim_In_Houston
Alsy, how many layers and what kind of glass do you plan to use on the new stringers? Just curious because I have no idea of how to replace stringers.
alsy
Hi Dave,
Sure nuf, your right on. The fir they are refering to must be douglas. thanks agn alsy |
fly hi
alsy
Hi Jim,
Don,t know yet. Have to do a little research on that. Probably roving and biaxial. Removed about 500 lbs. of wet foam (my guess). Alsy |
fly hi
