  New Posts New Posts RSS Feed - Speedometer Poll
Speedometer Poll
Jim_In_Houston View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Topic: Speedometer Poll
    Posted: April-27-2005 at 2:54pm
My '68 does not have a speedometer. Trying to evaluate a prop and fine tune the ignition timing without a speedometer is a guessing game.
So, I am searching Ebay for a speedometer.
Your opinions as to the best and worst brands of speedometers?
I have an unused 2" hole in my cardboard dash panel. Does someome make a 2" speedometer?
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2005 at 3:17pm
I might have a spare airguide speedo (used)that I would sell cheap. SKIDIM still sells compatible pick-up pitots. I believe the speedo needs a 4" hole (might be 3.5", can't remember right now). I do not think anyone makes a speedo for a 2" hole. Otherwise, your more common choices are Faria and Teleflex.
Now tell me how a speedo will help with engine timing? FWIW, I use my tach to gauge and control speed more than my speedo on the '77.
wesman View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote wesman Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2005 at 3:24pm
I have for sale some new old stock OEM Airguide Speedometer Pitot pickups that are the same ones used on the Nautiques. The hole pattern is the same and everything. These are still in their original packaging with hardware and instructions. Email me at wbdalton@satx.rr.com if you are interested.
jameski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameski Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2005 at 7:38pm
Jim, My boat had a 65mph teleflex spedo originally. It reads like a log scale (low speed graduations close together, high speed graduations far apart). I hated it because I spend most of my time pulling at the lower speeds and it was hard to read. I replaced it with an Airguide, which is contralog (the opposite of log) and I love it! There are also electronic spedos available. They have a scale with even graduations all the way up and they run off of a paddle-wheel.
current boat
94 Sport Nautique
previous boat
78 Martinique
kenny g View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenny g Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2005 at 7:41pm
jim , correct craft is using faria gauges on the new boats.
i like the chesapeake ss series.
http://info@boatersland.com
kenny g
scomer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scomer Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2005 at 12:20am
Jim,
    This may sound crazy but if you are only wanting to tune your boat and check your prop you may consider a hand held GPS monitor(one that displays speed). This will give you an accurate reading and you can use it from one boat to another to calibrate with. I have a Garmin E-Trex and it was $100.00 and it gives you the speed and mine is accurate to my truck's speedometer.
    Now if you are wanting to install a speedometer in your boat for everyday use and not just for the tuning, then my GPS idea might not be feasible. Although,I clip mine in between the two airguides when i'm in my boat, I think it is more accurate than the boat and it never needs adjusting.
Just an idea
SCOMER
