  New Posts New Posts RSS Feed - Tecumseh carb
Tecumseh carb
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Topic: Tecumseh carb
    Posted: November-09-2009 at 3:36pm
Has anyone ever played with a Tecunseh float type carb? My walk behind 5HP blower started giving me problems this spring with the carb overflowing with gas. After several attempts of cleaning I finally shook the float only to find to had a hole in it!! I got a new float as well as a rebuild kit - You know one of the kits that has about 100 parts in it and you only need 2 of them!! I changed out the needle and seat and it still overflowed with gas. I opened it up again and lowered the float level by bending the brass tab on the float up. Well, that didn't work ether!! I'm about to pull the seat out again and take a look to see if anything is obvious.
harddock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote harddock Quote  Post ReplyReply Direct Link To This Post Posted: November-09-2009 at 4:47pm
Did lowering the float level allow more fuel? Maybe raising the level?
anthonylizardi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote anthonylizardi Quote  Post ReplyReply Direct Link To This Post Posted: November-09-2009 at 4:59pm
Don't know what king of needle you have but if you are using the needle that is all metal then make sure you remove the seat from the barrel. Preassure air from the other side works, careful since the seat will out of the barrell, use a rag or somethign to catch it. When you put the new seat make sure it goes all the in into the seat, make sure you dont kink the seat. Also, the seat has a smooth side, that side should go facing the the needle. If is wrong it won't stop the gas flow. Put the carb upside down, the float should be slightly up, about 1-5 degrees. This will help closing the valve. If you close it too much the motor might quick at high RPM since it will run out of gas. Also, the bowl screw has some holes on the side, is very common for them to get clog. Get a small wire, like a bag tie and use the wire to clean the hole. Let me know if that works, When I was a child I used to fix lawnmover at my brother's shop. I remember most of the things.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-09-2009 at 5:14pm
Kevin,
My thought on lowering the fuel level in the bowl was to put more pressure on the needle/seat so the fuel wouldn't run out.
Anthony,
It's a rubber seat and all metal needle. Interesting on the seat position. I could have sworn that the instructions stated groved side of the rubber towards the needle!! I infact had installed it smooth side towards the needle first and then pulled it out to reverse it. I will pull the seat again and give it a try. That's for the tip on the correct float level setting. I'll check it too when I pull the carb again but now it does run fine at high RPM's. I'll keep you informed on how it works. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-15-2009 at 8:16pm
Anthony,
Thanks for the advice on the seat position. It worked!! I finished turning the seat over a couple of hours ago and no gas out the carb. I wish I had saved the directions. I still think they state to put the grooved side of the rubber seat towards the needle. After posting the problem, Billy called me up and cautioned me on cleaning the counter bore in the carb under the seat. Evidently the area can get real gummed up. He also said to be real careful no to scratch the bore of the needle and seat.
What a site - I wonder if you can get advice on fixing your lawn equipment over on the MC site!!!
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: November-15-2009 at 9:14pm
Pete - It never fails - I start up the blower in November & it runs fine. 1st snow storm I am out there pulling the plug or or screwing with the carb. Last year I think I got frost bite in my finger pulling the plug. This year I am going to start it once a week, it probably will still choke when needed.
I'm glad you got it going. There is so much knowledge on this site that Keith could start charging for it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-16-2009 at 10:51am
The only good thing that came out of the leaking carb problem is I think I got rid of the skunks that had made a home under my yard shed. The gas leaking out of the carb and then down through the sheds floor did it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote behindpropeller Quote  Post ReplyReply Direct Link To This Post Posted: November-16-2009 at 3:19pm
Pete-
Side note:
Check out these new Epoxy floats that they developed for airplane carbs. A typical piston driven airplane carb really isn't much different than a carb on a tractor. My guess is the ethanol fuel is giving your carb trouble over time...
http://www.youtube.com/watch?v=cG639ESY9-4
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-16-2009 at 4:27pm
Originally posted by behindpropeller behindpropeller wrote:
Pete-
It was actually the float problem I mentioned. The brass float had a hole in it. I really didn't even need to mess with the needle and seat but bought the rebuild kit at the same time as the float.
BTW, for my gas powered lawn equipment, I buy premium gas! Not that much more money and I do feel it helps with the typical problems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote behindpropeller Quote  Post ReplyReply Direct Link To This Post Posted: November-16-2009 at 4:55pm
Pete-
Pete-
Do you really think premium gas has less alcohol in it than lower grades?
It probably does not make a difference since you only run 20 or gallons through your lawn equipment anyway.
One of my neighbors says that their boat runs much better on premium gas, (240hp 351) which seems odd to me.
Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-16-2009 at 5:44pm
Tim,
I realize that the premium is a ethanol. Hard to get away from it but, I do feel it does have more additives that should help with keeping things clean. I too have heard of peoples claim to engines getting performance gains from running high octains that aren't needed. It's all in their minds!!!
BTW, I'm getting about 7 seconds from 0 to 60 on my EFI mower!
Post Options Post Options   Thanks (0) Thanks(0)   Quote harddock Quote  Post ReplyReply Direct Link To This Post Posted: November-16-2009 at 7:52pm
I have found with lawn equip, snow blowers, generators etc. that in addition to premium and sta-bil shutting off the tank and running the carb out of gas being a big help. Maybe my imagination but it's working for me so I'll continue.
SUNAPEE CROW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SUNAPEE CROW Quote  Post ReplyReply Direct Link To This Post Posted: November-16-2009 at 8:47pm
Sort of on the same topic. I have given up on trying to get Stabil into various powered yard tools at the end of the season. I mix it in the gas year round. The only exception is the riding mower in the spring and summer months when I consume a lot of fuel. Chainsaws,weed whacker, log splitter,etc. You never know what the fuel level will be when you are done for the season.
emccallum View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote emccallum Quote  Post ReplyReply Direct Link To This Post Posted: November-17-2009 at 12:13am
I agree, I put stabil in every gas can I use. I got tired of the ethanol ruining all the gas lines/primer bulbs in my power equipment and I put in a 280gal tank at the house. I have it filled with mid grade ethanol free fuel. As best I can tell I get about 5-10% better fuel economy with ethanol free fuel in my truck. It costs a bit more than Walmart, but I know what I am getting and it sure is convenient!
