  New Posts New Posts RSS Feed - How to tell which model.
Shaughn View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shaughn Quote  Post ReplyReply Direct Link To This Post Topic: How to tell which model.
    Posted: May-03-2005 at 7:03am
Hi, how can I tell which model I have purchased? The Coast Guard placard lists it as a "Ski Tique 179". It was purchased in pieces part way through a professional restoration - it has a PCM Ford 240HP engine, the dash has the woodgrain finish.
Thanks, Shaughn.
yellowdog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote yellowdog Quote  Post ReplyReply Direct Link To This Post Posted: May-03-2005 at 9:24am
Call or email Correct Craft with the hull number, they can tell you what you have. Very helpful folks!
Caretaker of the wife's '78 Ski Nautique
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shaughn Quote  Post ReplyReply Direct Link To This Post Posted: May-03-2005 at 10:26am
Thanks YellowDog!
swamp demon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote swamp demon Quote  Post ReplyReply Direct Link To This Post Posted: May-03-2005 at 12:12pm
It sounds like you have a 179. The original ski tique was 16' the next generation is 17'9" the 179 also had side vents on the windshield we have a 179 that we bought new,still runs strong
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shaughn Quote  Post ReplyReply Direct Link To This Post Posted: May-03-2005 at 1:06pm
Swamp Demon, I'm pretty sure that's the one from looking at the brochures. Is there anything special I should know? It has the PCM351 being rebuilt as we speak, recon 600VacSec Holley - there is absolutely nothing in it at the moment apart from the prop shaft, everything else is out and being restored. Sounds like a lot of engine for a pretty small boat! I notice the floors under the front seats are pretty bad, but I've read about this in regard to these boats.
Post Options Post Options   Thanks (0) Thanks(0)   Quote swamp demon Quote  Post ReplyReply Direct Link To This Post Posted: May-03-2005 at 4:36pm
Ours and the other two that were on the lake both have 302 4v. sounds like yours is really gonna haul. Ours will run 50 mph with the 302.
you should talk to 79nautique BC at wawasee he claims 60 mph with some mods ( Engine and prop)I believe. Other than normal items that wear out(starter,water pump points& plugs) we havent had any problems I think we have about 700 hours
                        Have FUN
