Need LH rotation distributor |
rtsuggs
Senior Member Joined: January-19-2010 Location: alabama Status: Offline Points: 300 |
Posted: February-01-2010 at 2:27pm |
I need a LH distributor for a 78 nautique with 351w..Actually all I need is the gear. if anyone has one let know..
Thanks |
Rob,
Did you confirm the rotation of your engine? I don't see any mention of it it your posts. Just want to make sure you get the correct gear for it. |
rtsuggs
Yea I'm sure. It's a LH. I chipped the gear when I was pressing it on.
Thanks |
critter
Platinum Member Joined: January-11-2008 Location: New Hill, NC Status: Offline Points: 1227 |
Rob, I have the LH gear that I took off of my Mallory. I swapped it out for a RH gear which I needed.
If you think that it will fit, I can send it to you. Not sure that the shaft size is the same. And the Mallory is pinned to the shaft. |
1980 Ski Nautique
1966 Barracuda |
rtsuggs
Thanks critter. I ordered one from mallory ($40} If it doesn't work out I'll get back with you..
Thanks |
