Keegan, your email |
Posted: February-12-2010 at 4:54pm |
Keegan,
I got your email via the site. The problem however is replying to a email via the site requires the sender to have a email address listed in their profile. If you hit "reply", it goes back to Keith!!!! I've made the mistake a couple of times! Keith is working on the issue. Your plan is sound. 12 oz. glass and tape in general but you can go to 4oz or 6oz. on the both sides of the plywood. Biax isn't bad but it does require more resin and isn't easy to form around corners like cloth. I guess I'm on the old fashioned side and say cloth is fine. The ideal screw for boat building is silicon bronze but pricy. You will see that lots use SS but if they get wet and stay wet they rust!! If you do go SS, make sure they are sealed/epoxied and don't get the "cheap" deck screws from the home center. But, I suggest using the screws only for holding the ply down (or weights if that will do it - test first) until the epoxy cures. Remove the screws and CPES/epoxy the holes. |
Keeganino
Grand Poobah Joined: October-27-2009 Location: North Carolina Status: Offline Points: 2063 |
thanks Pete my email is keeganino76@hotmail.com. I still have a couple of direct questions I want to ask you. If you don't mind shoot me something at that address so I can get back to you there.
1973 Skier |
keegan,
I emailed you from my home email address this afternoon. Did you get it? |
Cslaten33
Senior Member Joined: December-21-2009 Location: Tulsa, OK Status: Offline Points: 150 |
Hey pete I sent you an email. did you get it?
Thanks Clark Slaten
