  New Posts New Posts RSS Feed - HORN DOESN’T WORK
HORN DOESN’T WORK
BrettB1 View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettB1 Quote  Post ReplyReply Direct Link To This Post Topic: HORN DOESN’T WORK
    Posted: May-12-2005 at 6:26pm
Hey guys, I've got another problem...my horn does not work on my 78 ski nautique. What steps do I need to follow to troubleshoot the problem.
nautique frk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nautique frk Quote  Post ReplyReply Direct Link To This Post Posted: May-12-2005 at 7:17pm
Is your horn located in the front Cowl ??
Sometimes if you dip the nose of the boat into a wake at idle speed , water will get into the horns (compact double horn ) and kill them . If that is not the case your swtich or wiring could be bad also check the fuse .
Mike
JEFF KOSTIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JEFF KOSTIS Quote  Post ReplyReply Direct Link To This Post Posted: May-13-2005 at 11:38pm
nautique frk is right, those horns dont like tons of water. If you have a current meter on the dash it will tell you alot. With the engine not running, hit the horn switch. If the current meter reads about 25 amps discharge, then your wiring/switch is prob ok and the horn diaphrams are stuck. They can be taken apart and cleaned. The hardest part is to set the diaphram initial tension to get them started, then adjust for best sound. If you dont have a current meter, turn on the stern light(or something similar) and see if it dims slightly when you hit the horn (motor off). if it dims, the horns are drawing current and need cleaning, if not, the wiring or switch may be bad. Good luck!!
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettB1 Quote  Post ReplyReply Direct Link To This Post Posted: May-17-2005 at 6:52pm
Thanks guys for the advice, I really appreciate it!
