  New Posts New Posts RSS Feed - M1 manifold studs
M1 manifold studs
peter1234 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter1234 Quote  Post ReplyReply Direct Link To This Post Topic: M1 manifold studs
    Posted: February-20-2010 at 7:09pm
Does anyone know of a hardware supply site or a place where i can find 3/8 16 x 1.5 studs and small headed nuts . the type that the edelbrock manifolds require? they are a 3/8 16 nut but have flats on them that would be equal to 5/16 nuts a half in wrench is used if you use a standard 3/8 16   9/16 wrench size nut they hit the manifolds when turning
81nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: February-20-2010 at 7:53pm
I got mine at a local Ace hardware store, they had a small selection to detrmine what I needed and then they ordered them for me. You can also find them at Summit racing but they are ARP and very expensive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter1234 Quote  Post ReplyReply Direct Link To This Post Posted: February-20-2010 at 8:40pm
thanks i will look it up
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: February-22-2010 at 2:04pm
the nuts are common and refered to as pannel nuts or jam nuts, you should be able to get the studs from any quality auto parts store.
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter1234 Quote  Post ReplyReply Direct Link To This Post Posted: February-22-2010 at 10:02pm
do you think something like the arp style 12 points should not impinge on the manifolds? the stud part is easy
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: February-22-2010 at 10:42pm
I used jam nuts and flat washers but had to put a flat on one side of the washer to get it to sit flush on the flange. You could try those 12 points but the washer part of the nut might still hit. Let me know if they work because I may change mine out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter1234 Quote  Post ReplyReply Direct Link To This Post Posted: February-23-2010 at 9:45pm
i think i might try those and grind the washer part slightly i had them polished at a chrome shop they look pretty sweet i think i will use olive green paint where the red usually is
