I Damaged My Boat - Need Advice/Help |
Post Reply | Page <12 |
Author | |||||
Buck4U
Newbie Joined: February-10-2010 Status: Offline Points: 27 |
The coupler is still attached; looks intact
It may be. I have two speedo pickups on the back of the boat, one on either side.
It might be. I really have no idea. The previous owner thought it was a '73 at first, but the last two digits of the serial number is "78" so he said it was probably a '78. Is there a way I can run the VIN? Here's some more pics: Shaft Log Strut - Thats just dirt on the leading edge of the strut Rudder Port Side View Rear View - Speedos on left and right |
It sure looks like it could be a '73- its definitely not a '78. Post a picture of the HIN.
I cant see any damage to the shaft log from that picture... thats how the bottom of the boat is supposed to look. What does it look like on the bilge side? |
Buck4U
Haven't had the chance to remove the inspection boar, rear seat, and tank just yet, but I will post more pics as soon as I do. Thats very interesting. I'm glad I haven't registered it yet. I will have to ask the dealer I purchased it from to make me a new Bill of Sale. Any idea on how to get the exact year model? I really appreciate the replies, guys. |
Chris,
I've never seen a spacer under the strut before. Makes you wonder if it came from the factory that way due to a drilling/position error?? |
Buck4U
Here is a closer picture of the strut with the suspect spacer:
Here is the "shaft log" I believe. Doesn't seem disturbed at all Here is the rudder port. Here is the strut "plate"(?) The cracks in the wood were there before my accident. The white stuff around the plate was peeling away. There is one large fin under my boat. Then there is this: Possibly the original speedo? I have a total of three speedometer gauges. One is mounted in the dash, and the other two have been attached to the dash with plexiglass bracket. Anyway, do you guys see any reason that I cannot just bolt the replacements in? Everything looks solid enough. Also, I noticed TRBenj asked to post a pick on the boats HIN. Where would I find that? |
SNobsessed
My guess is that the rudder had been straightened once before & was work hardened right at the break point. Just took 1 more hit for it to let go. It looks like the shaft came out of the coupler- shouldn't do that but it probably saved your tranny. Possible the shaft came loose, had no safety collar, then took the rudder with it when it went out the stern.
PS, stick with the log hit when talking to the insurance adjuster! |
Air206
Lotta weird situations there......
Did you loosen that rudder jam nut? Seems odd to look that way.... The force to shear off that rudder would HAVE to have damaged the fiberglass if it wasn't already weakened/repaired/partially fractured. Looks like the rest just fell out when it separated from the coupling. The fins, shims, strut "backing plate" and loose "chaulk" sure are VERY interesting............... I'm sure you can get that back together.. (but you know the guys are gonna see that wood support and tell you to check your stringers...... you'll then wanna strip out everything, re-string, re-floor, align new drive parts and engine........ your early 70's CC will be good as new......that is just what this site and these folks are GREAT to help with......... |
Buck4U
Alright. I'll save up the money for the replacements and see how they do. Thanks for the help, guys.
Air206 - I haven't loosened the nut, just removed the seat and took pictures. SNobsessed - Sorry I didn't mention this earlier, but the boat isn't insured. I had it listed at non-operable since I was chasing electrical issues and dealing with a leaky car, so sadly I can't claim my insurance on this one. |
kapla
that´s the problem when showing pictures of your naked lady LOL!! |
<a href="">1992 ski nautique
Morfoot
Jeff, I'm with Chris on this one. From the pictures I see it looks like you suffered no gel damage to the boat. The drive shaft and prop have departed the boat in tact only taking the rudder with it. Get your scuba gear and retrieve the missing parts and you'll have some more clues as to what happened.
Looks like the second tracking fin has been dressed up to next to the point of it isn't doing you any good if that is what it is. Is that factory or someone else's idea of a torque fix? Maybe someone who knows more about this particular year can chime in and tell you what it is. TRBenj? Guy's would the spacer under the strut be a previous owners attempt at getting the tranny couplers to align? Could that have caused a sress point in the driveshaft causing it to depart the boat? |
lewy2001
My guess is that the boat has had a hit before and the rudder was straightened. Is the coupler showing signs of wear (fretting) where the prop shaft exited. Misalignment more than likely caused this wear if present. Then the prop shaft just worked it's way out taking the rudder on its way.
hotboat
Gold Member Joined: March-28-2009 Location: Conn Lake Pa Status: Offline Points: 814 |
The small fin is the same speedo pickup on my 78. I would agree, earlier than 78 model. See if the hin # is on the upper rt hand corner of transom on the outside.
Brian
This certainly is a good theory and I feel quite possible. Have you got the prop and shaft out of the lake yet? A picture of it would be helpfull. Take a close up of the coupling end. Jeff, Did you ever do the alignment on the boat? Posted Feb. 22nd:
If Im not mistaken the early Martiniques only had a single tracking fin- the 2nd gen SN had 2. While everything is apart, I would check the remaining underwater gear (fin, strut) for straightness. If bent, get them fixed while everything is apart.
The theory that the shaft worked its way out and caused all this sure sounds plausable. I would pay very special attention to the alignment when you put it back together. If you can, eliminate that spacer under the strut. As I mentioned before, I would go with a used rudder (or even a prop) but a new shaft and coupler is a wise idea. Like has been mentioned, that small fin is the speedo pickup. Ive got the same one on my '71 Skier. If there is no HIN on the upper right side of the transom, then poke around the bilge- there may be a plate with a serial number affixed to a stringer. Either that, or there is a serial number on the capacity plate by the throttle. Thats the only thing I have on my Skier, and Correct Craft was able to pull the records and confirm the year. |
Buck4U
Yeah, the stringers definitely need replaced. I haven't found any rot on the primaries, although I'm sure there is. The engine mount bolts all hold torque, so I've decided that the stringer job will wait until after this season.
8122 - Never checked alignment with a feeler gauge, just spun the shaft and found it easy to spin (crappy test, I know). The boat hasn't been run for more than 20 minutes other than the day of the accident, but I've secured a set of feeler gauges, and printed Eric's Alignment thread for reference when I get the new gear in there. Haven't gotten the gear out of the lake yet. I've got drill this weekend, so it's going to be sometime early next week before I have gear in hand. I will post pictures when I get it. TRBenj - Thanks for the HIN location info. I will find the number and send it to Correct Craft for verification. Thanks again, guys! The wealth of knowledge here never ceases to amaze me. |
