  New Posts New Posts RSS Feed - trailer bearings ’76 tique
yater View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote yater Quote  Post ReplyReply Direct Link To This Post Topic: trailer bearings ’76 tique
    Posted: May-23-2005 at 2:03am
Stock trailer needs bearings. Anyone know where I would have the best chance finding them? Size?
74 Skier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 74 Skier Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2005 at 3:51am
I got mine at Advanced Auto, you can find those anywhere. I took one of the old bearings down there and matched them, believe its a very common size.
Shake and Bake
1974 Skier
Post Options Post Options   Thanks (0) Thanks(0)   Quote yater Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2005 at 3:53am
Forgot to mention I'll need the hub too. I had a little problem on the way home. The axle wasted the hub but hopefully the axle is alright. I guess I'll have to slip the bearings on to find out.
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2005 at 11:23am
I get stuff like that at Agri Supply. It's a chain of stores for farmers, they have axles, springs, wheels and hubs cheap.
Tim D
Post Options Post Options   Thanks (0) Thanks(0)   Quote yater Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2005 at 3:05pm
Ok so my inner bearings are apparently MUCH larger than the outer ones. I bought the 1 1/16" kit from tractor supply and the bolt pattern fits the wheel, the outer bearings are fine, but the inner ones look like they would be 1 3/4" or something. Anyone? Also, my axle is hammered and I'll need a new one. Any ideas? I'm NOT happy right now
Jim_In_Houston View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2005 at 3:12pm
Believe it or not, I saw a package of trailer wheel bearings hanging on a peg in the boat trailer accessory aisle at WalMart. I have no clue as to the size required but I imagine there are only a couple of "standard" sizes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote yater Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2005 at 4:27pm
I found the right bearings and hub at a local boat shop. Now I have to file the melted metal off of the axle to fit them on. Turning into a project in itself to get this thing to the water
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2005 at 4:40pm
I feel your pain.
