  New Posts New Posts RSS Feed - New Strainer
New Strainer
Brian View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Quote  Post ReplyReply Direct Link To This Post Topic: New Strainer
    Posted: May-23-2005 at 9:42pm
I have an 82SN that I need to replace the strainer on. Unfortunately the boat is about 120 miles from here and I want to order one without making the trip! Can anyone tell me what diameter the hose is that runs from the pick up to the strainer and from the strainer to the water pump.
Brian
DJ77skier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DJ77skier Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2005 at 9:49pm
call vince at discount inboard maine he can tell you what you need and supply you with it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2005 at 9:52pm
DJ77skier,
Thanks...I am a big fan of Skidim and buy from the often.
Unfortunately they do not have the strainer I am looking for. I am looking for a Vetus strainer since that is what is in the boat and the hose connections are from the botton of the strainer (I have not seen this set up on other brands and I am trying to avoid replacing all of the hose).
Still looking for hose diameter, let me know if you can help!
Brian
Bob's2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob's2001 Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2005 at 10:28am
I had one of those and they are like hen's teeth. Nobody has one. I replaced it with a Sherwood strainer and 90 degree hose barbs so they point down and used the same hoses. My 83 uses 1" hoses, in and out.
Bob Ed
83 2001
Brad_K View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad_K Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2005 at 11:37am
If anyone has a picture of a strainer at hand could you please post it as i have no idea of what i am looking for and think i need to change or at least clean it.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2005 at 4:20pm
Thanks....I was able to find a new strainer lid and o rings at Midwest Correct Craft.
Brian
wesman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wesman Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2005 at 3:39pm
Brian, in case you do end up replacing with a Sherwood strainer, here is some additional info. I have an 84 SN with a Commander marine 351. Everything was a 1" hose fitting eexcept the transmission oil cooler, which was 1 1/4 ". The original raw water pump for the Commander engine was replaced by the original owner with a Sherwood pump with 1" fittings, so I do not know the fitting size of the original Jabsco pump. Hope that helps!
Wesman
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob's2001 Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2005 at 9:00pm
Brad_K this link will take you to strainers at SkiDIM. There are pictures.
http://www.skidim.com/products.asp?dept=1006
Bob Ed
83 2001
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad_K Quote  Post ReplyReply Direct Link To This Post Posted: May-27-2005 at 7:45am
thanks, it makes things os much easier when you know what your looking for
