  New Posts New Posts RSS Feed - Where did I go wrong with alignment
MAN - GA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MAN - GA Quote  Post ReplyReply Direct Link To This Post Topic: Where did I go wrong with alignment
    Posted: June-14-2010 at 11:35am
I have a 75 Mustang - this is the second time this season I have fiddled with the alignment - first try after printing out and following the alignment posts from this site I was not quite sure on a couple things and contacted FFM for some advice on my oder setup - second attempt on Friday evening went good and I was very confident I was under the .003" and everything felt real good... well I took the kids out first thing Saturday morning and I felt a small vibration right after putting the boat into gear that I had not felt before (really conscious of things on the boat due to its age) the vibration was only felt at idle speed - anything over about 800-900rpms and the boat felt real smooth
where did I go wrong? or am I just being too super conscious of trying to get things perfect and letting my mind take over
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2010 at 11:55am
Sounds like the alignment isn't the cause of the vibration. In fact, misalignment in many cases with "snub" vibration due to the slight binding on the shaft.
Have you checked the straightness of the shaft? How's the cutlass bearing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MAN - GA Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2010 at 12:06pm
there doesn't feel like there is any slop in the bearing and I have never had the shaft off the boat to check straightness there is no evidence on prop or strut of every hitting anything that would affect the shaft - the alignment was not very far off when I initally checked it - I only had to raise the front of the motor about 1/4-1/2 turn to get it aligned - maybe I should pull everything apart again and recheck the alignment
open to suggestions
malibud View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote malibud Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2010 at 12:10pm
agree w/ brainard I had the samething happen out of alignment and put back and vibration cutlass bearing was bad and shaft was bent slightly
