  New Posts New Posts RSS Feed - Help i lost my prop... [:^(]
jonas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jonas Quote  Post ReplyReply Direct Link To This Post Topic: Help i lost my prop... [:^(]
    Posted: July-04-2010 at 6:38pm
I lost my prop on 5 meters of water today so I'll need to get a new one.
I have a 76 mustang 17 with a 351.
I think it was a nibral 4 blade 15x18 that was modifyed to 15x16
I't was a bit slow out of the hole but dit 50+mph.
I would like to get more holeshot speed cause i'm not using the topend speed...
I'm located i denmark so i will have to import one.
By the way i't sucks when u are towed in by a bayliner at 14:00 when there is a carnival i the harbor
OverMyHead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OverMyHead Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2010 at 12:29am
Ouch! I have read about shaft taper problems leading to props spining off. someone will come a long that knows what they are talking about and explain. Just dont want to see you loose another one( or get towed by another bayliner!)
1987 Ski Nautique
davidg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote davidg Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2010 at 12:49pm
Were you using a castle nut with a cotter pin to keep the old prop on? I have heard of people having props come off with those.
I have been using a nylock nut on mine the past few years with no issues at all. I would highly recommend checking this out when you get your new prop.
Nylock Nut
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2010 at 1:08pm
The problem with those is your only really supposed to use them once.If your losing a castilated one with a cotter key something is wrong.Look up Pete's how to on how to lap a prop to the shaft.
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2010 at 1:26pm
'76 Mustang 17 w/351
15x18?   15x16?
Are you absolutely sure?
Think your 5 might be a 2.
AT
horkn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote horkn Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2010 at 3:10pm
That is a mighty big prop.
As far as the nut, castellated nuts work fine, but verify the nut and pin are fine. Nyloc's can be used, but they are really only designed to be used 1 time. After that, it can spin off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jonas Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2010 at 3:34pm
Thank's for the quick replys...
So I looked up the nautique dealer in denmark today and he saved my week he had a 13x13 oj in stok so i'll be runing that in the weekend if the weather acts nice
I'm dead sure on the the numbers on the old prop but I dont know if they match the pro after it has been modifyed. I never had it over 4100 rmp and still did 50 mph but it was slow out of the hole. A friend of mine has a bailiner 175 with 140 hp inbord engine and he had no problem keping up with me out of the hole
I hope my new prop will put and end to that...
Here is a view you dont want to se form your boat...
86BFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 86BFN Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2010 at 4:57pm
propably should us the tow ring on the front of the keel instead of the lifting ring on the bow.
Hey at least the bayliner had a gal to look at while being towed!
👣 Steve
86 Barefoot Nautique
89 Martinique
Former Owner: 93 Hydrodyne 350 MAG
Post Options Post Options   Thanks (0) Thanks(0)   Quote jonas Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2010 at 5:30pm
By the way I was using the castle nut... got a new one with the new prop so that's what i'll be using...
but belive me i'll be cheking it often
Nylon nuts in inches are rare in denmark it's all mm. here...
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2010 at 9:08pm
Jonas,
Yes, next time don't let a Bayliner owner tow you from the lifting eye!! Hopefully no damage was done except to you'r pride. (A cc being pulled by a Bayliner!! )
I suggest you take a look at this thread and read it.
proper prop installation The nut whether it's a Nylock or castellated, is there only to set the prop on it's taper and then as a safety from prop loss. I mention in the linked thread that the nut is not there to keep the prop on and I've seen boats come in with the nut gone but the props still there. The bottom line is the prop you lost was NOT put on properly!!!
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2010 at 11:39am
Make sure its a RH prop else you'll still be loosing races.
BTW where does your engine box get its ventalation now?
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote jonas Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2010 at 6:31pm
Pete
I read your post yesterday and i did it that way...
The prop is on now and I am waiting for some good weather...
Gottaski
Well if it's a LH prop I'll still try to take him in rewerse
I have tre intakes on the box instead. I needed the space for a storage compartment...
86BFN
I know it's not the right place to tie the rope but it's so much more easy to reach
Post Options Post Options   Thanks (0) Thanks(0)   Quote behindpropeller Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2010 at 6:43pm
Typically installing them 5 times is the limit. Better check your data.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jonas Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2010 at 8:54pm
So I had it out today and it's like a new boat. The acceleration is off the charts it will hit 5000 rpm in no time so i have to be careful with the throttle... not sure on the the top speed but i will get the gps in next week. By the way I kicked the h... out of a jet ski today so i am looking forward to getting out with the gayliners next week...
