  New Posts New Posts RSS Feed - Eric - Control valve O-ring?
FrankT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FrankT Quote  Post ReplyReply Direct Link To This Post Topic: Eric - Control valve O-ring?
    Posted: July-11-2010 at 5:09pm
Eric, hate to bother you for such a trivial part but I have tried to order the O-ring for the control valve but am told that this part is back ordered. Can you source or do you have the specifications so I can order from McMaster Carr?
FrankT
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-11-2010 at 5:19pm
Frank,
You'd end up with having to get at least 50 if you went to McMaster! That supply would last quite some time! Go to a decent hardware store or even one of the home centers. They will have Buna-N "O" rings.
EDIT: In the size range you need, the McMaster package quantity is 100!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote FrankT Quote  Post ReplyReply Direct Link To This Post Posted: July-12-2010 at 1:06am
Thanks - I will give it a try. Not certain that the big box hardware stores are going to have it.
FrankT
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: July-12-2010 at 10:02am
normal buna like pete says. hardware store
