Starboard Instrument Panel 2000 SN |
mdevir
Newbie Joined: July-19-2010 Location: Indianapolis Status: Offline Points: 8 |
Posted: July-19-2010 at 2:23pm |
2000 SN have all lights green and no response on gauges. Is this gauge shot, or any options on repair or fix? Appears cost is $330 to $375?
M3Fan
Make sure your voltage to the dash is good. Also, check the additional ground wire in the battery compartment to make sure it has a good connection.
mdevir
Port side is working fine, only the right side. I will check out ground. Thanks
mdevir
Checked battery cables this am and pulled dash. Inspected gauge pod, and traced down to what assume is boat ECM (like car). Checked all what appear to be circuit breakers and all seemed OK (none popped). Connection to starboard gauges is only a 4-pin connector. Lights were off, but none of the buttons responded when depressed. At this point think replacement is only option. Any parts source cheaper than White Lake which is around $330?
M3Fan
Probably not, that's about what they cost. Might want to try N3Boatworks.com.
