351w heads |
1morepass ![]() Newbie ![]() Joined: July-15-2004 Location: United States Status: Offline Points: 7 |
![]() ![]() ![]() ![]() ![]() Posted: June-15-2005 at 11:41am |
I have a set of marine 351w heads sitting in the garage that I do not have a use for. Anyone interested?
1morepass
ScottZ ![]() Platinum Member ![]() ![]() Joined: January-20-2004 Location: Clanton, AL Status: Offline Points: 1164 |
What condition are they in and how old are they?
Lake Mitchell , AL 1984 Ski Nautique 1972 Skier |
They are in good condition and have been resurfaced,magnafluxed and gone thru at a head shop. I took them off my old engine when I repowered the boat last year. They just need a good cleaning then ready to go.
1morepass
Andy B ![]() Guest ![]() |
Are these GT-40 or standard heads?
nate ![]() Newbie ![]() Joined: August-07-2005 Location: United States Status: Offline Points: 5 |
How much do you want for them ?
1morepass ![]() Guest ![]() |
they are standard marine heads
make me a offer
reidp ![]() Platinum Member ![]() ![]() Joined: December-06-2003 Location: Mooresville, NC Status: Offline Points: 1804 |
Could you provide the casting number from the heads or whether they are the 5/8" or 13/16" spark plug size. This will also determine the valve size and combustion chamber size. The standard 351 5/8" plug head is the smaller valve/larger chamber that was used on most 240 HP engines. The large plug/larger valve/smaller chamber head was used on the earlier engines (250-255 HP etc) and will raise the compression considerably on a later model engine. FWIW.
yep i will get the cast #'s tonight!
