Bow Tie Cam Shopping (RH) |
Whitfield
Senior Member Joined: July-30-2009 Location: Central Va Status: Offline Points: 449 |
Posted: September-26-2010 at 6:51pm |
Shopping for a RH rotation Chevy 350 cam.
No good leads yet. Cam MFGs are closed... My choice for engines are: Pre 86 first gen or 1997 Vortec Roller cam. Vortec roller cam with GM part # list for over $600 online with none found so far. Price and availability will determine my next move as I've found a fresh built (Stock) marine Rh long block for under $1k (with cam). |
Michael ....
I'm the black sheep ~ 1984 Dixie 299 Super Skier (350 Chev PCM / counter rotation / Velvet drive) Open Bow. |
Fl Inboards
Grand Poobah Joined: January-20-2008 Location: United States Status: Offline Points: 2119 |
PCM Part number RA050022 RH 5.7 97/later $476.00 plus shipping.
Florida Inboards inc. floridainboardsatmsndotcom. I can only assume it is a roller cam but will find out for sure! |
Whitfield
Might look to see if I can substitute a RA050012 in the Vortec. If not then I know I can build the old block and swap for the Vortec heads.
I need to research if my 1984 cam/crank gear drive set will work on the 97 Vortec cam/crank. Lunati can grind me a standard flat tappet CR cam for just under $200 Crane doesn't do CR cams any more. |
Michael ....
uk1979
Platinum Member Joined: June-13-2007 Location: United Kingdom Status: Offline Points: 1423 |
Whitfield, have a look on the Melling web site they run out standard RH cams for Chevy's, cost is low here so must be in the USA.
Lets have a go
56 Starflite 77 SN 78 SN 80 BFN |
Whitfield
~ ~ ~ Thanks UK 1979, I'll take a look. I'm finding lots of listing with very little in stock. Looks like the economy has killed off 80%+ parts inventory.
Can anyone confirm the RH vortec cam timing assembly. It looks to be chain drive as where all previous GM Small block models were gear drive. I say this because I find a parts breakdown for RH rotation that includes cam and distributor gear but no new timing set. Intake $200 / Cam Flordia Inboards $500 / New RWP $175 =$900 + just to swap to the Vortec ~~~~ $900 + Building the engine ... Gotta think about that one... |
Michael ....
Whitfield
Unless I'm seeing it wrong ~ ~
Melling's Marine catalouge only offers the 96 and earlier flat tappet (Non roller) cam in counter rotation. |
Michael ....
Whitfield
Just missed a NEW Melling 22125 on Ebay for less then $25
Michael ....
uk1979
Whitfield,Have a look at these Cloyes BY2534 Cam and BY2535 Crank you need to find out if there fit on a Vortec roller cam,can't be sure but the Vortec is different.Yes if you are thinking of going RH full vortec engine then its $$$ keep the cost down its old type block with vortec heads,or just go standard LH vortec engine and use the PCM 1.23 gearbox as the money you save on the rebuild gets you well on the way to a new box or a good rebuilt one and still have the prop going the right way.
Lets have a go
Whitfield
I can't find any reference to the gears fitting the Vortec cam ~ Looks like they don't.
Michael ....
Fl Inboards
It,s a double roller Timing chain in The RH Vortec Chevy, we just had one (08 in a 79 Ski Nautique)apart yesterday and got it back running this morning, Stephen is finializing for a run at the lake tomorrow morning.
Whitfield
Thanks Jody! That confirms my suspicions.
I'm working to source out the remaining counter rotation (marine) acessories. My engnie is a 97 Truck vortec that I'll need refresh and to convert. |
Michael ....
eric lavine
remember to flip them pistons, its a must
make sure you have a boss to run a fuel pump, or you will be going to an electric one |
Whitfield
Michael ....
baitkiller
A left hand prop is easier and cheaper. I Know I know I know.. shut up and sit down.
