  New Posts New Posts RSS Feed - Fuel not getting to carburetor
jodil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jodil Quote  Post ReplyReply Direct Link To This Post Topic: Fuel not getting to carburetor
    Posted: September-27-2010 at 11:39pm
I recently purchased a '94 Ski Nautique, which hasn't been run in several months. The engine is turning but isn't getting fuel up to the carburetor. Any suggestions for what may be wrong &/or how to fix it?
Keeganino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2010 at 11:43pm
Welcome to the site. Fuel pump maybe? Somebody more knowledgeable will chime in shortly I'm sure.
1973 Skier
MartyMabe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MartyMabe Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2010 at 11:50pm
Anti-siphon valve at tank? fuel filter clogged?fuel pump? pump on carb?Has anyone installed a shut-off valve on the fuel line?
66 Skylark
93 SN
If you're not living in NC, you're just camping out!
horkn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote horkn Quote  Post ReplyReply Direct Link To This Post Posted: September-28-2010 at 3:06am
In addition to what Marty mentioned, did you try squirting gas into the carb while cranking it over?
Otherwise, try a line from the inlet of the fuel pump to a gas can gas can to run that way to eliminate any issues from the filter to the tank.
Also, make sure it has spark too.
