  New Posts New Posts RSS Feed - 2000 Air Nautique engine issue
discobay2005 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote discobay2005 Quote  Post ReplyReply Direct Link To This Post Topic: 2000 Air Nautique engine issue
    Posted: June-30-2005 at 8:51pm
The engine just started cutting out over 3750 RPM. Any idea what could be causing the problem?
Thanks in Advance!
Chris
bkhallpass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bkhallpass Quote  Post ReplyReply Direct Link To This Post Posted: June-30-2005 at 9:13pm
It sounds like the boat is going into
limp home mode (the computer senses something
wrong and kicks it down to idle so you
can get home but don't blow up an engine).
I don't know what is causing your issue.
In my case, I was two quarts low on oil.
When I was at idle or low speeds, no problem.
When I would speed up, apparently the low oil
was detected.
Perhaps not your issue, but real easy to check
you fluid levels. Other common cause is
overheating, but I would expect that at
different speeds, not just high rpms.
BKH
Livin' the Dream
Post Options Post Options   Thanks (0) Thanks(0)   Quote discobay2005 Quote  Post ReplyReply Direct Link To This Post Posted: June-30-2005 at 9:19pm
Thanks for the feedback. We just got a tuneup done at the dealership so they should have replaced all vital fluids.
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2005 at 12:36pm
Yes, but a faulty limp mode sensor can cause the problem. Something a tune-up or fluid check will not solve. Disconnect the wire from one sensor at a time to see if you problem goes away. If so, replace that sensor (really just a switch to ground).
The temp switch looks like the water temperature sender and is located in the intake manifold water jacket. The oil pressure switch is "tee"ed off the pipe leading to the oil pressure sending unit.
