Looking for a 6A6 Strut and 40" shaft |
Author | ||
MAN - GA
Senior Member Joined: July-09-2009 Location: Cumming, GA Status: Offline Points: 298 |
Posted: November-29-2010 at 4:06pm |
for my 1975 Mustang 16
THANKS |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21185 |
Any particular reason why you want a 6A6? That strut will fit just fine, but has a 1" longer body than your original 6A (6" vs. 5").
I assume youre looking for one that is not bent? Ive got a 6A but it needs to be straightened. I looked high and low for a good used shaft for my sister's boat this summer but came up empty. You may find that you have to go with a new ARE for ~$300. |
Riley
Tim, I had one and now I've got 2. I'll measure them and see if they're 40". I'm not sure how to tell how straight they are as they have flanges on them.
Ha, I guess I was looking in the wrong place Bruce!
I only found one used one listed here on the site and the seller wanted $125+shipping and couldnt promise it wasnt bent (and wasnt willing to refund me if it ended up being junk). I gave up the one to Nick's Skier for the time being, so I may be in trouble if we ever get that boat back in the water. |
MAN - GA
correct I am looking for a 6A - original post was a typo I knew there were both out there - understand the earlier BFNs used the 6A6
mine is slightly bent right at the flange connection to bottom of hull - it is enough that I can't get the alignment 100% under .003 - I cannot locate anyone that can straighten the strut so any recommendations will be appreciated so I can evaluate the cost delta from just purchasing a new one or straighten and buy new bushings |
Actually the early (79-80) BFN's used the same 6A strut... though the later direct drives got the 6A6. If your shaft is long enough, you can run the 6A6 with the longer body- but check to see what your prop to strut clearance is now. The extra 1" of length is all on the aft end, so you'd need close to 1.5" of clearance now in order to fit it.
Im surprised that you cant find anyone to straighten yours for you... I havent had one done myself but was always told it wasnt a big deal and that prop shops could do it. Maybe its worth calling Delta, etc if your local places wont touch it? |
Riley
I have one with a flange that came off a VD tranny. It is 40". email me if you're interested. A machine shop ought to be able to straighten yours.
Tim, for $125 with no promise or refund if it were bent? You must not have been dealing with a hobbyist. |
Dtaylor373
Senior Member Joined: June-30-2004 Location: United States Status: Offline Points: 167 |
I have a 40" long 1" dia shaft from a 77 Ski Tique. I will take $100.00 for it. for the fellow in Georgia, looking for one I will be in Gainesville GA. tommorrow nite, Cartersville GA on Wednesday night, can bring the shaft, if you are interested. I feel that the shaft is pretty true and straight. Will be leaving Birmingham around 11 in the morning your time, if interested respond to Dtaylor2954@yahoo.com with contact number and I will bring it. Will be checking email before leaving.
David T
Dtaylor373
Forgot to say, there is no flange on this one, shaft only
David T
Mark, You need to start with a strut alignment so the shaft runs true through the center line of the boat and the hull hole/log. Stainless flat washers under the strut flange are used to kick the strut in the direction needed. Yes, the best is to have it straightened but I've seen (from the factory) and used shims under brand new struts. Once you've got the shaft aligned to the hull, then go to the engine and align it to the shaft. Regarding the straightening, have you called prop shops in your area? Machine shops with a arbor press? We even have members (Chris is one I remember) with access to a press do it themselves. |
Fl Inboards
Grand Poobah Joined: January-20-2008 Location: United States Status: Offline Points: 2119 |
I have had Stanless Steel struts fabricated when a stock replacement was unaccessable or non exsistant. As far as "shimming" a strut, this is a process that is not generally recomended as the strut base needs to sit flush to the hull surface, gel cracking or even failure at the fastner points can occure. Yes this at one time was a accepted practice but again not recomended. Sounds like the strut may just neeed a minor tweek, I have a large press and would be more then happy to take a look at your strut and adjust it if it can be done.
MAN - GA
Pete and Jody thanks for the input - here is my dilemma as it stands right now the 6A strut is no longer available and the 6A6 is the only one available as Tim pointed out yesterday the difference is the prop log length of 5" vs. 6". My current setup has 1 1/4" from the end of the strut to the back of prop if I have to purchase a 6A6 strut that will leave only 1/4" from the end of the strut to the back of the prop. I did take advantage of the Delta Propeller promotion and order an Acme 1210 yesterday and without knowing the dimensions on the Acme I don't know if I will be able to get any more room if I have to go to the 6A6 strut, but I assume the prop shaft taper will have the Acme seating in about the same location as the current Federal prop. Here is some questions for the resident experts on the forum.
1. What is the safe (minimum) distance between strut and prop 2. I did call a local machine shop with a press yesterday and they asked what material composition the strut was? Are these solid bronze? 3. Why I am at it I want to replace the cutlass in the hull - what size/length is it and where do I purchase? Thanks and sorry if this is too much info for the "Parts Wanted" section of the forums, but the input was already coming so I didn't want to start a new post. And as a side note I have already been printed the prop lapping post by Pete and am getting the materials together to do this procedure when I get everything with the strut and put the assembly back together |
Riley
I'm sure there is a theoretical answer to this, but 2 inboards I work on both have very little space between the 2 and are 22 and 30 years old, came this way from the factory and there have never been any problems because of this, other than the PIA of having to seperate the flanges to back the shaft off to fit a prop puller on. |
If Im not mistaken, the closer the prop is to the strut, the better- you just want to leave some room to get a puller on there. 1/4" might be pushing it, but should be enough for most pullers. Ive seen CC factory clearances run between 1/2" and 1-1/2".
I think you'll really like that Acme 1210. It should fit on the shaft in roughly the same place as the old prop. |
MAN - GA
Just got off the phone with a local machine shop who has been in business 40yrs and has experience with straightening struts before and they sounded knowledgable over the phone (for what that is worth). Is it worth having the couple faces redone why I have it off. Also getting them to check shaft straightness on their equipment - so if there is anything else anyone can offer up some advice on why I am in the process
THANKS |
Fl Inboards
Provided you do not want to replace your old parts you are on the right track getting it straightened and checked out.
MAN - GA
is it better to pull the prop while everything is still on the boat or can I go ahead and start removing rudder, pull shaft, remove strut before the new prop and prop puller come to the front door from Delta
Jody, I stated this but forgot to mention it in this thread:
A stainless flat washer is about .050". With bedding in 5200, I feel the practice is still sound. Mark, Report back on how close the shop is able to get the strur straightened. |
DMJY
Newbie Joined: December-15-2010 Status: Offline Points: 2 |
What can I do if I fail so many times?To be or not to be?
Da Bear
Newbie Joined: December-12-2010 Location: Oklahoma Status: Offline Points: 13 |
I have a new 41" shaft measured end to end
Here are some pics the non tapered end does have a keyway. http://i1126.photobucket.com/albums/l608/wulf311/100_1661.jpg http://i1126.photobucket.com/albums/l608/wulf311/100_1660.jpg http://i1126.photobucket.com/albums/l608/wulf311/100_1659.jpg |
Riley
Anyone know the length of the shaft used on a Barracuda?
