  New Posts New Posts RSS Feed - powerstroke motor swap
wakeboardin2k4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakeboardin2k4 Quote  Post ReplyReply Direct Link To This Post Topic: powerstroke motor swap
    Posted: December-14-2010 at 9:09pm
So since I don't have any projects going on my boat right now and the motor in my truck has a crack in the block I have been working on that. Here are some pics, nothing thrilling but a project no less.
The motor on the left during the side is the old motor. You can see where the water pump should be there is some corrosion from the previous owner not using the correct anti freeze I believe. You can also see the corrosion in the picture of the original motor still in the truck. The original motor is pretty young, only 88000 miles. I have also been told that if you do not use a certain additive, which may already be inside the correct anti freeze, that it will eat through the block. Which is exactly what happened to me.
The previous owner sold it to me with JB weld on the block in a spot I couldn't see during the inspection.
"I'm planning to bring my girl that rides on a trailer with me and leave my girl that complains about camping at home"
Mrusso94 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrusso94 Quote  Post ReplyReply Direct Link To This Post Posted: December-14-2010 at 11:05pm
Yikes.. Thats a used donor though I'm guessing? They're not always easy to come by.. good score there..
      BTW I'm looking for a mid nineties F250-350, preferably diesel. I'm in west milford as well if you come across another one shoot me a PM.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakeboardin2k4 Quote  Post ReplyReply Direct Link To This Post Posted: December-15-2010 at 12:54am
Ill keep my eye out. Are you looking for reg cab, extended, or crew cab?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrusso94 Quote  Post ReplyReply Direct Link To This Post Posted: December-18-2010 at 2:47am
Thanks! Regular cab, or extended..    Would settle with a crew cab if the rest of the truck was what i'm looking for, and for the right price..
