floating trailer help |
Double Up
Newbie Joined: July-17-2008 Location: St. Pete FL Status: Offline Points: 39 |
Posted: December-17-2010 at 2:57am |
I have a rollins trailer for my 90 sport, and when i launch the boat the trailer floats. It is more of a problem when I am putting it back on the trailer. I think it is a combination of the tires and the wooden bunks. I tried filling PVC with sand but that was not enough. Concrete? Any Ideas?
thanks! |
1990 Sport Nautique
storm34
Wow, I've never heard of anything like this on a larger trailer. Does it have larger fenders or step plates that could be holding air when you back it into the water? Otherwise, I wouldn't see a reason for it floating?? I'll be curious to see how this plays out!!
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5781 |
Is the trailer a tube frame construction? If so maybe the frame is just holding air and a few holes drilled at a high and low spot would allow the frame to fill with water and sink.
The trailer for my 81 with the fiberglass fenders will float when retrieving the boat if we back in too quick. It will actually move a few feet to the side before it sinks, we just have to back in slower and let the air escape from under the fenders. |
Donald80SN
Grand Poobah Joined: January-12-2009 Location: Denver, NC Status: Offline Points: 3896 |
Just an idea, but are you in the water too deep? Try putting the trailer in with the fenders barely out of the water. You may be already doing this.
I hope this helps, Donald |
Someone didn't put 12.50's by 16.5's on the trailer did they?
mdvalant
Grand Poobah Joined: May-06-2009 Location: Bellevue, IA Status: Offline Points: 2059 |
Never heard of this...
the same sort of thing happened to us on a duck hunt this year though...except the boat was frozen to the trailer...That was quite the surprise haha |
bhectus
Platinum Member Joined: July-04-2010 Location: Gator Country! Status: Offline Points: 1809 |
pics or it didn't happen!!
'87 Barefoot - sold '97 Super Sport Nautique - originally custom built for Walt Meloon '97 Ski Nautique '83 SN 2001 |
Bret, What don't you believe happened without photographic proof? The floating trailer or the boat frozen to the trailer? |
OverMyHead
Grand Poobah Joined: March-14-2008 Location: MN Status: Offline Points: 4861 |
My old tubular bayliner trailer if backed in quikly would float briefly then sink usualy one side first then the other. I would have drilled it if it took longer to sink.
1987 Ski Nautique |
rman56
Gold Member Joined: April-13-2009 Location: Kansas Status: Offline Points: 661 |
I have had good luck with putting my trailer right to the top of the fenders, easy on and off. I bought a Dorsey for my 83 and they have nice sized drain holes so it sinks right away......
1983 Ski Nautique
harddock
Platinum Member Joined: June-04-2008 Location: Toontown, MA Status: Offline Points: 1763 |
Call rollins and see what they suggest.
