  New Posts New Posts RSS Feed - tach wiring color code
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Topic: tach wiring color code
    Posted: January-24-2011 at 3:06am
I'm changing out my replacement gauges with more period correct Teleflex ones.Since they are used I have no wiring instructions.The small gauges are pretty obvious since they are marked,but I have some questions about the tach.It has 4 wires,Red,Black,Grey and Light Blue. The Light Blue is for the lights and the Blace is the ground. I'm guessing the Red is power and the Grey is the signal from the coil? I have looked thru the wiring diagrams in the reference section and don't see any of these color combinations. Anyone have any ideas? These gauges were out of a Mercruiser if that helps.Thanks guys.
dwcar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dwcar Quote  Post ReplyReply Direct Link To This Post Posted: January-24-2011 at 3:17am
Gary,
Those gauges look brand new. Where and how did you find them?
83Ski
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: January-24-2011 at 9:57am
usually the gray wire powers the tach, i believe to the negative side of the coil
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: January-24-2011 at 11:34am
Gary, your assumptions on the wiring colors is exactly right. Gray = tach feed.
Keeganino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: January-24-2011 at 7:27pm
Those look mint. Are these the ones that were on Ebay? I almost picked them up myself if these are the same ones I wish I would have. Nice score! My gauges are identical. Right now the tach, oil pressure and ammeter do not work. Would like to get them running before this season starts.
1973 Skier
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: January-24-2011 at 9:25pm
Thanks for the help guy's.Yes these were the ones off of ebay,I have been looking for a long time.They cleaned up real well,I believe the bezels are stainless,so I was able to buff them up.The insides of the glass is a little dirty,but after all the boats not new either.
MartyMabe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MartyMabe Quote  Post ReplyReply Direct Link To This Post Posted: January-24-2011 at 10:41pm
Aw- Gary, let's put prisim tape on that dash and put digital gauges in there, make a 20" LCD screen come up out of the dash and hang some dice off the rear-view mirror, and a BIG pair of NU ! off the exhaust!
66 Skylark
93 SN
If you're not living in NC, you're just camping out!
