  New Posts New Posts RSS Feed - Dock Fuel Transfer
Dock Fuel Transfer
Air206 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Topic: Dock Fuel Transfer
    Posted: February-06-2011 at 7:35pm
I'm looking for some ideas on fueling the boat on the lift. We usually bring gas from home out to the lake, walk down the slope with the gas cans and fuel in the lift or down on the dock. The problem is with these "Enviro" gas can spouts, it's killing me to fuel the boat. Holding the tab down, lifting the gas can up and trying to fuel through the recessed "unleaded" hole in the fuel fill tube is getting tiresome. I was thinking of using one of the 15 gallon semi-portable tanks that Northern sells and extending the hose to the dock. I like the idea of the nozzle end for control and gravity to feed the fuel in. What are you guys doing to get this accomplished easier and smoother?
If I go with the 15+ gallon fuel tank mounted in the shed on the dock, I would like a fairly light gas-proof hose that a 15-20 foot spool would be easy to deal with. Any ideas? Thanks............
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: February-06-2011 at 8:01pm
Since my boat is small I just carry 5 gallon gas cans and use one of these siphons.You can get them at Bass Pro. I also have one of these mine came with a hand crank pump,but it took forever to pump and you arm was ready to fall off.I took off the pump and now it looks like the one in the picture.If the boat is alot lower than the dock, it works fine,but say you only have about 10 gallons in the portable tank and your dock is low it won't start to siphon.It is easier to move around tho especially if you need alot of gas and to fill it I made a carrier that fits into my reciever hitch
MartyMabe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MartyMabe Quote  Post ReplyReply Direct Link To This Post Posted: February-06-2011 at 8:07pm
Steve, you need one of these bad boys!!
66 Skylark
93 SN
If you're not living in NC, you're just camping out!
Waterdog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: February-06-2011 at 8:35pm
Steve,
    I use a Holley blue 12 volt pump 110 gal. per hr. I put 2 clips on the wires off an old 2 amp trickle battery charger. It will pump 15 ft. up hill. Works well.
- waterdog -
78 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: February-06-2011 at 8:57pm
I Love it Marty!
I prolly can get that at Race City Marine! Ha!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2011 at 4:10am
Andy -
Like the idea of the pump. Most of the fuel transfer pumps are really heavy, spendy and designed to be atop a barrel. What fuel line do you use? Do you have a nozzle on it? Does it do OK against the off valve? The Holley site says it is not compatible with methanol/alcohol.... they mean straight fuels for dragsters, not blends, right? Thanks Man!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2011 at 9:14am
Steve,
"KIS" and let gravity do the job. My shoreline has a slope to it as well and requires a run of stairs. (18 rises) I purchased one of the 13 gallon wheeled poly totes figuring that was the largest the wife could lift into the car. 50 feet of 3/4" fuel rated poly tubing and some plastic (solvent rated) cam lock quick connects at the tank made it a simple set up keeping the tote at the top of the hill. I used the ball valve on the boat end of the tubing that came with the gas tote. The tubing and cam lock fittings came from Mcmaster. The tubing stays on the hill. The length out to the lift gets wound up on a garden hose reel mounted on the side of the stair railing when it's not being used.
tullfooter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tullfooter Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2011 at 10:13am
If your going to stick with 5 gallon cans, VP racing has the best cans I've ever used. Amazon has them, but I've actually found them cheaper at my PWC shop. They are rigged up with a 10" clear hose. The can empties in less than a minute. I threw away my #%@%$ CARB compliant cans.
Play hard, life's not a trial run.
'85 BFN
'90 BFN
White Lake, Michigan
SN206 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SN206 Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2011 at 10:55am
I have several of the VP fuel cans myself for the dirt bikes. Never thought of using them for the boat, but that's a great idea!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2011 at 11:33am
Steve, I've seen guys attach a huge funnel to the post with clear tubing long enough to reach the boat. Stick the tubing into the fuel tank then stand on the dock with your five gallon can with the pour spout removed and dump it down the funnel. Empties a 5 gallon can in no time.
JMurph View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JMurph Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2011 at 11:47am
The only thing I worry about with this method is really knowing how much fuel to put in the boat. It's hard to the fuel once it's been poured into the funnel. I guess you could have a valve at the boat side of the tube to turn it off. This is the way my Uncle Jack filled his pontoon for years. Not always a pretty sight.
Waterdog,
The fuel pump method sounds interested. I started searching around for different pumps and the more I thought out how I would get it assembled, I realized keeping a battery charged for this purpose didn't sound like something I'm interested in. I mainly don't like the idea of hooking up the clips to the battery to fill the boat with gas. The safety courses have you turn off all of the electrical components in the boat prior to fueling for obvious fear of a spark.
I currently us the siphon that Gary referenced. That siphon is a beast. You still have to handle the gas cans though. If anyone is going to handle gas cans, then those siphons are the way to go IMO. They will also empty a five gallon can pretty quickly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2011 at 12:12pm
My dad built a "gas pizazzer" out of PVC that fits this description. The side fuel fills on the TSC2+ boats are a PITA to fill directly. The funnel attaches to the dock post so theres no more bending over while you fill- much nicer. Just dont try to top it off, like JMurph said.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2011 at 12:25pm
I do have a "jiggler" siphon it works good. I can see your point w/sparks off the batt connections. If your not comfortable with it then don't use it. The leads on my pump are 6 ft long or so. It would be safer if I had a on/off in line thou. I hook the pump up first then open the fuel. I've never seen a spark while connecting the batt. (Positive cable first on - first off.) The pump is made for fuel so I transfer fuel with it. Last weekend I used it to move fuel oil from one tank to another 150 gals. in a little more than an hour.
- waterdog -
78 Ski Tique
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2011 at 2:08pm
I have a Super Siphon and it works great:
Super Siphon
I stole the idea from my friend's dad. I fuel my boat with the boat in the water, and the dock is higher so once you get it started, it feeds fast.
If your boat is in the air, you can put a towel down on your transom (to protect) then rest the can on your transom. Then just get it started by quickly dipping the check ball end a few times, then gravity does the rest. It's surprisingly fast too.
WakeSlayer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WakeSlayer Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2011 at 2:38pm
I use the jigglers. I use them for everything; mower, Allis, quad, boats, plow truck.   Cheap and easy.
Mike N
1968 Mustang
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2011 at 2:55pm
Been using the Jiggler/Super Siphon for many years now and it works great for me, if there is a place to set your can that is not lower then the fill its virtually hands free once you get it started.
86BFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 86BFN Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2011 at 3:45pm
ditto. I load the boat while it's fueling up.
👣 Steve
86 Barefoot Nautique
89 Martinique
Former Owner: 93 Hydrodyne 350 MAG
05 210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 05 210 Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2011 at 2:39am
Originally posted by quinner quinner wrote:
Been using the Jiggler for my nads. It's virtually hands free once you get it started
   Mike
Air Nautique 210 Team
640 hours, not 1 regret
PLBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PLBC Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2011 at 3:22am
99
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2011 at 12:44pm
Hey, hey guys. I like the Jigglers too, but now we're getting way off topic.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2013 at 1:01pm
This is the hand siphon method. No jiggler needed. Tall skinny plastic cans work the best. The new gas cans without the vent are actually a blessing since it's just another part to break off and leak (and you have to seal it off to get the siphon going). The crappy nozzle goes in the garbage can and seal disc is all that is used. Some cans you might need to keep the nozzle to make a seal for transport.
If you really want to get as much gas out as possible lift it up higher, make sure the hose is buried deep in a corner and tilt the can. On a good fill there's nothing left to even pour out, it'll evaporate. If you just leave the can sit there obviously there will be some left, which I'm able to pour in the tank without the need for a nozzle.
