  New Posts New Posts RSS Feed - 1969 correct craft
1969 correct craft
charlie View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote charlie Quote  Post ReplyReply Direct Link To This Post Topic: 1969 correct craft
    Posted: July-20-2005 at 12:22pm
Help!
I have a 1969 San Juan model correct craft.It is 24 ft. with a 318 chrysler inboard.I cant take it out in a light chop without soaking everyone in the boat.I would like to know if anyone there knows about splash rails. I would like to know the weight of the boat and is this model a planning boat.
I would appreciate any help you can give.
many thanks Charlie Lloyd
jameski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameski Quote  Post ReplyReply Direct Link To This Post Posted: July-20-2005 at 2:42pm
There is a San Juan in the '68 Brochure in the "Reference" section of this web site. It shows a wieght of 4400 lbs (and all the passengers are dry).
current boat
94 Sport Nautique
previous boat
78 Martinique
Bhedbloom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bhedbloom Quote  Post ReplyReply Direct Link To This Post Posted: July-21-2005 at 8:59pm
Charlie,
Is the water spray coming in from over the bow, or is a side wind blowing it in over the gunwales? Also, who gets wet, the driver or the passengers in the back? What size chop and what lake are you taking your boat out on? Maybe I can shed some light on the subject for you if I have more info.
Barry
Barry, South Carolina
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote charlie Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2005 at 3:55am
The splash comes over the bow from both driver and passenger sides.It wets anyone just behind the wind shield.I also get splash from three thirds of the way back of the boat which wets passengers in the back.The size of the chop does not have to be more than two to three foot waves or less. I REALLY LOVE THIS BOAT so I hope someone can help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bhedbloom Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2005 at 1:03pm
Charlie,
The only thing I can think is that the bow is heavier than it should be because of one of the following reasons: Too much cargo up front in the cuddy and/or the foam under the floor between the stringers and the gunwales have become water logged causing the boat to sit too low in the water while under power.
Under power the bow of the boat should be quite a bit higher than the stern due to the inboard configuration and hull design. My 20' Southwind has the same "Softride" hull design as your San Juan. We had our Southwind 20'out over the weekend in some chop (inland lake, protected water) and she cut it with no problem. I don't know where you are using the boat, but it is not necessarily the best sea going vessel even though it is a large boat. I sure would love to see some photos of your boat. Please also post your boat in the Diaries section of this web site as we are lacking a San Juan in that section. If you do ever decide to sell or see another San Juan for sale please let me know. I have been looking to add one to my collection. Hope this helps, and Happy Boating!
Barry/ South Carolina
Bhedbloom@aol.com
Charlie View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2005 at 7:57pm
Thanks for your help.I will take some pictures and post them.The boat is a little rough it sat for 12 years before I bought it.I have completely rebuilt the 318 and velvet drive with all new acc.I have 6000.00 into it not counting the trailer.I have put a fresh water cooling system in it.
Thanks again
64 Skier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 64 Skier Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2005 at 5:11am
Charlie, if you haven't removed the old foam then you may want to drill a few holes to check. My boat, like yours was completely rebuilt...but I could tell something was a little off by the way she road in the water and like you, waves of any size were not taken well. I drilled through the glass, 3/4" plywood and into the foam and it was wet. With the foam removed and a 542 Acme on a bored and rebuilt engine it's like a new boat. Hope this helps.
64 Skier
66" HO VTX and 67" HO Triumph
71CC
S.T. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote S.T. Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2005 at 2:37pm
Shouldn't the foam be closed-cell? If so, how can it absorb water? What's the deal?
dchris17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dchris17 Quote  Post ReplyReply Direct Link To This Post Posted: July-29-2005 at 12:55am
Here's a good site explaining why foam soaks up water and how to get rid of it. It's also good reference for fiberglass repair, including replacing floors & stringers, gelcoat problems, etc.
How to drain water from foam
Hull repair
Enjoy!
