  New Posts New Posts RSS Feed - motor oil
motor oil
tlsecrest View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tlsecrest Quote  Post ReplyReply Direct Link To This Post Topic: motor oil
    Posted: April-19-2011 at 10:30pm
I have an 87 Martinique. Ford 351. I plan on putting Mobile 1 5w20 fully synthetic oil in it. Does anybody see a problem with that?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2011 at 10:35pm
Oh wow!!!!!! Yes, there is a problem!!!! It's far from what that flat tappet engine needs. You can do a search on site and read all about the importance of ZDDP.
I must ask, who told you to run the 5W20 synthetic?
sweet77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sweet77 Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2011 at 12:20am
Rotella T straight 30w with a motorcraft filter
76 Nautique
"If you do what you always did,You'll get what you always got!"
"An empty wagon makes t
skicat2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skicat2001 Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2011 at 12:30am
I been told 20w 50. and a fram filter... just kidding boys...
I heard these ol long stroke motors do better with a heavier weight motor oil. Hope this helps
1985 CC 2001-SOLD
Lee Michael Johnson
Post Options Post Options   Thanks (0) Thanks(0)   Quote sweet77 Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2011 at 12:47am
HERE
Here is the difference between flat tapped and roller.. however i am a HUGE mobil 1 fan love there motor oil however rotella t is in my boat but if your stuck on mobil 1 theyoffer a number of oil products which are higher in phosphorus. Mobil 1 15W-50 (1,200 ppm), Mobil 1 0W-40 (1,000 ppm) and Mobil 1 High Mileage 5W-30, 10W-30 and 10W-40 (900 ppm).
76 Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote tlsecrest Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2011 at 1:15am
last year I ran a mobil 1 10w40 synthetic. I just happened to have a 5w20 synthetic. Wasn't sure if it would make a big differnce or not. Probably stick with the 10w40.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2011 at 1:26am
Do you get points deducted for a new oil filter? I hope not,I can't afford an original
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2011 at 9:36am
holy chit, 269 bucks....
levinmark View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levinmark Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2011 at 10:37am
Tim,
I opened that can of worms a few months back, you can search for "Oil reccomendations" under my username and see how heated this topic can get. Personally, I have always used Mobil 1 myself, in all my vehicles. But chose not to in the Nautique. After listening to these guys on there input, I used the Valvoline VR1 20w-50 Racing Oil. It is specific for the flat tappet cams and is highly reccomended by most on this site. Take a look at that post, these guys know there stuff!
levin
Mick88 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mick88 Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2011 at 1:04pm
running at 160 to 170 degree heat range your motor
never gets that hot. A straight weight is what most are
running since you never see 210 degrees. SAE-30,5w-30
and 10w-30 are all 30w at 210 degrees. But at 160-170
they are 5w 10w and 30w. Oil lubricates your engine,
not additives. ( insert girl friend joke here)
