  New Posts New Posts RSS Feed - 84' Ski Nautique 2001 Rebuild
Mcrosby33 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mcrosby33 Quote  Post ReplyReply Direct Link To This Post Topic: 84' Ski Nautique 2001 Rebuild
    Posted: May-05-2011 at 3:31pm
Pin it To Win it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2011 at 4:13pm
I just noticed you were in MA. Where abouts?
Originally posted by Mcrosby33 Mcrosby33 wrote:
im also ripping up the old carpet, floor, and foam and redoing it. I hope to put some pics up soon but im stuck at college for another week -_- Thanks!
I have to ask- why are you redoing the floor and foam?
If you have any soft spots (between the engine box and battery box, where the front seats screw down) then youve got rot going on. Ive yet to see a boat with rot in the floor that had not spread to the stringers. I would anticipate replacing everything while youre in there, if I were you.
Also, if youre planning on leaving the foam out when you rebuild, you'll need to replace the structural support that it gave to the hull-floor structure. The most common way to achieve this is to add horizontal ribs between the stringers and hull walls. Theres a lot of info here discussing foam vs. no foam and other aspects of full structural rebuilds. I would encourage you to search the site and do a lot of reading before going much further.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mcrosby33 Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2011 at 4:42pm
Southwick Ma. I live about 10 minutes from the Congamond Lakes but my family has a summer home on Otis Resevoir in East Otis Mass which is where we keep and use the Nautique.
It wasnt soft spots that made me want to undertake this project. Where the carpeting on the floor met the carpeting on the side of the boat it was starting to sag and the top fiberglass layer of the floor had cracked along the side of the boat creating a wobble in the floor. Also the carpeting in general was just in poor shape. Surprisingly when i took the entire floor up, the only wood rot that I came across was a small piece between the ski pilon and the battery box.
As for Foam vs. No foam, yes I have most definetly been looking into that. It seems as if each one has there pros and cons. A LOT of info out there. Just cant wait to get home and get to work.
Pin it To Win it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2011 at 5:04pm
I work about 20 min from Congamond. A buddy of mine grew up on Otis. Small world.
The reason the only soft spots will occur between the front of the motorbox and the back of the battery box is because thats the only part of the floor that has wood in it. The rest is glass directly over the foam- so it wont get soft, even if theres water underneath. I would inspect the stringers very carefully before buttoning it back up... it would be a shame to tear it apart twice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2011 at 5:32pm
As he decribed it sounds like the floor has seperated from the wall.
Not good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2011 at 5:40pm
Not good.
Matt,
I agree! Keep digging and investigating.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mcrosby33 Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2011 at 5:51pm
Regardless of whether I choose foam or no foam, when it comes to replacing the floor should I just use marine plywood? My local boat shop said that would do fine, and if I want I can even do a layer of fiberglass on top of that, just dont do any on the under side so it can breathe.
As for inspecting the stringers, I will be sure to do that as soon as I get back home.
Pin it To Win it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2011 at 6:15pm
Since there is a TON of info on this site, buried deep within other peoples rebuilds, which may or may not get repeated in this thread, Ill reiterate:
No on the marine ply- its 4x the cost of regular exterior ply and is unnecessary for this application. Both marine and exterior grade use waterproof glue.
Going back with a ply floor is fine. Glassing only the top may or may not be ok (I would glass both, personally), but not because "you want the underside to breathe". Do not walk, RUN from whoever is giving that advice. You will want to CPES and coat the ply with resin. regardless of how much glass you put on it.
I would be very surprised if you cant find some degree of rot in the stringers. That has not been the case in any of the CC's I have torn into up to this point.
mglines View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mglines Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2011 at 7:04pm
Mcrosby,
How did you get the carpet out and what did you do to clean up the floor after you pulld it out?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mcrosby33 Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2011 at 7:44pm
I just pulled the Carpet up, and I removed the floor completely, I had no use in trying to clean it up.
Pin it To Win it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2011 at 8:57pm
I totally agree to get away from whoever told you the bottom side of the ply needed to breath. Please tell us, is the the local boat shop who is giving you that advice.
Yes, reading through some of the stringer job threads will give you the best advice.
BTW, that boat shop must have lots of marine ply they need to get rid of!! Did they even bother to tell you the difference between it and exterior? If not, it's the inner ply voids. Since marine is always structural, only very small gaps between the inner veneers are allowed and also tightly controlled knots and dutchman's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2011 at 12:43am
If you foam then the floor is not going to breath.
