  New Posts New Posts RSS Feed - perfect pass on 206 year 2007 pcm 330
laurie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote laurie Quote  Post ReplyReply Direct Link To This Post Topic: perfect pass on 206 year 2007 pcm 330
    Posted: May-08-2011 at 12:29pm
guys
Travelling at 30mph (gps) however pp says 24mph (no wonder im using tons of fuel)
any ideas whats happening.The paddle wheel spins freely
Could it do with the servo motor (where is this)or linkages. My raw water filter hose seems to foul/ touch on the throttle linkage also (must adjust this)
I changed my throttle sensor 6 mths ago, but maybe nothing to do with this issue??????
tx laurie
laurie
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2011 at 1:07pm
Sounds like you need to synchronize the PP speed using a GPS, scroll through the menus, believe it is "Speedo Adjust". Dial it up/dn until correct using 32mph as your check point, assuming that is your most commonly pulled speed.
