  New Posts New Posts RSS Feed - Which Spark Plug?  1985 2001 Ski Nautique
 Post Reply Post Reply Page    <12
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2020 at 7:21am
Originally posted by merbesfield merbesfield wrote:
I left the gap at .40. We will see.
A .40 gap is kinda beyond huge, a .040 gap on the other hand sound a lot better
Autolite 24 plugs at .040 inch gap with your Pertronix will be OK.
Points used .035 inch plug gap through the years and it would work just fine with your Pertronix also.
Pertronix generally says you can open your gap about .005 to .007 with their ignition setup.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2020 at 10:30am
I missed the points/pertronix distinction, Ken. Thanks for clarifying. I don’t like to be one of those guys that gives bad info. (Like 75% of the posters over on FB)
merbesfield View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote merbesfield Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2020 at 12:30pm
Thx guys. .040 is what we went with. Unfortunately it didn’t really fix very slight shudder at idle. Any ideas?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2020 at 1:17pm
How about some additional info on the shudder you mentioned. Define shudder. In gear? Idle only? On acceleration? What rpm does the shudder disappear?
A transmission damper plate can clatter/shudder as well as the transmission gears at very low idle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote merbesfield Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2020 at 7:18pm
The shudder is at idle as your moving thru the no wake zones. WOT is no problem at least doesn’t feel like it. Boats flys at full throttle. Shutter is also present even if you push the throttle up a little but over the idle speed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2020 at 7:29pm
Mark,
The shudder - like it's not running on all cylinders?
Post Options Post Options   Thanks (0) Thanks(0)   Quote merbesfield Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2020 at 8:31pm
Sort of like that yes. On lake as I type. Again WOT it flies but moving slow at idle or even 3000 RPMs has a shutter about kind of shakes a little bit
