  New Posts New Posts RSS Feed - Wildcat with exhaust leak, maybe
 Post Reply Post Reply Page    <12
66Wildcat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 66Wildcat Quote  Post ReplyReply Direct Link To This Post Posted: June-25-2011 at 1:06am
Good advice BuffaloBFN. I've been taking pictures when I remember to. I've been adding them to the photobucket site here
http://s1195.photobucket.com/albums/aa392/fesser1/66%20Wildcat/
I would link them to here but it takes me so long to figure out what I am doing that it seems like time wasted.
With the assistance of my youngest daughter, I was able to at least find the biggest leak. If you look at the photos you will see a simple splice or junction of the two straight exhaust tubes, with two stainless hose clamps. When I put a hose into the exhaust outlet, water trickled in at this coupling. I was surprised because I expected it to come from the elbow that is just below the exhaust manifold outlet. The elbow is rusty and ugly, but, with water in the exhaust tube, the coupling in the middle leaked and the elbow didn't. That said, if I make it through the week that I really need the boat, I would like to replace the elbows and the parts that pass through the transom. Is this hardware readily available? Sorry for the long posts, but if it wasn't for this site, I would be trying to reinvent the wheel on everything I do with this boat. Frank
66 Wildcat, 401ci Buick
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-25-2011 at 9:47am
link to Frank's photobucket
Frank,
Glad you found the problem. It looks like a PO ran out of hose and did the splice. Ether that or he couldn't read the tape measure!!!
Actually, I feel it may have been a repair job without pulling the floor - just using the available space in the cavity and sliding the exhaust fore and aft.
BTW, all hose connections below the waterline should be double clamped. That's what the USCG tells us!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 66Wildcat Quote  Post ReplyReply Direct Link To This Post Posted: June-25-2011 at 12:55pm
I think you are right Peter. I found a weird combination of stuff that looked really old and stuff that looked pretty fresh. The starboard side is even stranger. The tube is definitely older and the through hull fitting has some copper that is crusty looking but that side is dry. I should have real fun today since I have all day to work on it. Frank
Post Options Post Options   Thanks (0) Thanks(0)   Quote 66Wildcat Quote  Post ReplyReply Direct Link To This Post Posted: June-25-2011 at 9:10pm
This is what it looks like when dumb people are allowed to work on old boats. This piece of galvanized tube that they used as a splice or coupler, is thinner than the rain gutters on my house. I wasted a 2 hour round trip to the closest Westmarine store thinking they would have exhaust components. Apparently shopping online makes more sense.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 66Wildcat Quote  Post ReplyReply Direct Link To This Post Posted: June-25-2011 at 9:16pm
My temporary solution was found at a muffler shop. The guy sold me a six inch section of 3 inch tailpipe for 6 bucks. I can get it to fit in the exhaust tubes which are 2 7/8. I am going to double clamp everything as Peter mentioned. Plan to foam around the exhaust and put the floor back temporarily. When we get back form the lake, the fun will start...gut interior, pull up floors, see what uglies are living down there. I am so glad I didn't just live with the leak one more time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 66Wildcat Quote  Post ReplyReply Direct Link To This Post Posted: June-25-2011 at 9:18pm
...and one more thing, thanks Pete for fixing the link to the boat pictures. Very helpful of you! Frank
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-25-2011 at 10:03pm
Frank,
Forget the foam! As mentioned, you may decide to go no foam after spending some time reading some of the threads about it. I happen to be a no foam person but there are other opinions as well.
OK, never shop at West - they are nothing but whores when it comes down to price. You can do better by simply doing on line searches. I happen to like go2marine.com.
The local muffler shop helped out but you do know it's temporary!! Even if they sold you SS tube, it's 400 series "muffler" stainless and it's junk!!!
We all want you to do a total at seasons end! we'll be witing and be around for any help you need!
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2011 at 12:51am
Very nice ride; well worth the effort!
On those pics, take all sorts of angles and under and behind anything you can get to. The ones that make your neighbors wonder might be the most valuable in the end.
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote 66Wildcat Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2011 at 3:33am
Pete, I put some foam in there before I checked in here. There were lots of crescent shaped passageways through the inner and outer stringers and the cross braces. I posted pictures of those areas as best I could. The pictures are actually what I was looking for before I started ripping the floor apart. It almost looks like the boat was designed not to have foam since there were so many passageways built into the stringers and crossmembers. Frank
Post Options Post Options   Thanks (0) Thanks(0)   Quote 66Wildcat Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2011 at 3:36am
BuffaloBFN, I am sticking the camera everywhere. Good advice. Frank
