  New Posts New Posts RSS Feed - 1983 sn /hard start sloggish
turk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote turk Quote  Post ReplyReply Direct Link To This Post Topic: 1983 sn /hard start sloggish
    Posted: June-22-2011 at 1:15am
Hi, have a 1983 sn.It is difficult to start,I have to keep idle at 1200rpms and then it is still not smooth.On take off it is VERY sluggish but then it takes off like a shot. Half speed and wide open run great.I've replace fuel filter. I was told the timing was 6 degrees before TDC (by a dealer). I had it right on the nose and it couldn't get out of it's own way.So while out in the lake I adjusted it by sound and feel (didn't have a light).AS I said it ran great after about 10 mph.Any advice appreciated. Thanks, Turk.
1982 Ski Nautique
1983 Ski Nautique
Ed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed Quote  Post ReplyReply Direct Link To This Post Posted: June-22-2011 at 4:08am
If you've exhausted all of your ignition possibilities, you may need a carb adjustment.
turk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote turk Quote  Post ReplyReply Direct Link To This Post Posted: June-22-2011 at 10:37am
Thanks Ed, not to sure of myself on the carb but willing to try anything because we're going on vacation this Friday. Sorry I'm new at this and trying to learn.Any pointers on the carb adjustment? Turk.
1982 Ski Nautique
1983 Ski Nautique
TimSpangler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimSpangler Quote  Post ReplyReply Direct Link To This Post Posted: June-22-2011 at 11:57am
The holley site has some good info on adjusting. I just rebuilt mine and followed the instructions and it runs great now. I had a similar issue, it would stall under 1200, rebuild fixed it.
TIM
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: June-22-2011 at 12:12pm
I concur you have some carb issues, but the avice you got regarding base timing is off. 6 degress it will certainly run like azz. 8-10 is more like it.
River Rat to Mole
